i want to lower 1-2",will this.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2005, 09:14 AM
its not my fault
hello i have a 85 camaro 350 t-5. i would like lower the car 1-2". how will this effect launch?
Old 03-05-2005, 09:25 AM
Ratchet's Avatar
Last journal entry: Ontario Camaro Nationals 2008
Unless you add lower control arm relocation brackets it will hurt the launch due to decrease in traction at the rear wheels.
If the lower control arms are on a downward angle from the rearend to the attachment point on the body any force applied by the drive wheels will push the lower control arms up thus causing a loss of traction at the rear wheels upon acceleration.
Its not about how low or high your car is for launch it is all about the suspension geometry and making sure it works the way it was designed.
Old 03-05-2005, 09:38 AM
malc's Avatar
Living At The Speed Of Life
If you do you will need to buy an anti-squat kit, available from Global West,
part number GB-238. www.nextgenparts.com have them for 139$ and they
bring the rear of your lower rear suspension arms down to their original location.If you have a 3" exhaust or like me, tubular subframe connectors, they will scrape, like on speed bumps.Also the front wheels will lean in at the top and have to be adjusted, all that done and the car will go like itīs on a rail.
BTW mine launches real good, better after installing the anti-squat kit, dead level.
Name:	global west exts.jpg
ID:	4096   Click image for larger version
ID:	4097   Click image for larger version
newbie question: how to lower my 48' Buick Super Conv. planet-risa Suspension - Brakes - Steering 2 03-31-2006 03:09 PM
one side is1.75" lower than the other side. brian400ex Suspension - Brakes - Steering 15 04-01-2004 04:34 PM
mustang 2 lower control arm bushings nomaddaddy Suspension - Brakes - Steering 1 02-14-2004 12:28 PM
Need to make a lower grille Jag Daddy Body - Exterior 2 05-10-2003 05:55 PM
Changing to lower control a arms for Must II Mooshaker Suspension - Brakes - Steering 2 02-02-2003 06:21 PM
