I want to rebuild the numbers matching water pump 69 Camaro... - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2008, 08:10 PM
I have a numbers matching 69 Camaro RS Convertible with a 327 that I am restoring. I am putting the finishing touches on the engine rebuild and I am trying to re-use as much numbers matching parts as possible. The engine has 50,000 original miles on it and has not been started since 1972. I am assuming the water pump will need rebuilt and was wondering what tips and thoughts on rebuilding it you folks may have. I don't think the fuel pump is any good as well as the starter and alternator. Should I rebuild those as well or just replace them?
Old 06-19-2008, 08:42 PM
Wiki Edits: 31
if it has a casting number and you want to rebuild it, it is possible.. I have used this guy for rebuilding my last carb. he does water pumps and fuel pump rebuilds also, but his restoration service is not cheap.. I'v never rebuilt a water pump myself and I would send it out if I wanted the same pump. http://www.classicpreservation.com/
rebuild the starter and alt.. there easy to rebuild, save money by going that way too
Old 06-20-2008, 08:30 AM
thanks...
Thanks Matt. I have found a few websites that walk you through the rebuild for some things. Matt, on a numbers matching car like this would I be better to just put auto parts store parts on it and save these originals in a box???
Old 06-20-2008, 08:46 AM
Wiki Edits: 31
that would make sense to do it that way. don't rebuild them until you want to put them on.. seals can dry up over time
Old 06-20-2008, 09:54 AM
Do search for cardone.My dad sent his wp off his 69 chevelle 396 to them and they rebuilt it for him.I think orielly auto parts can send it for u also.
Old 06-20-2008, 02:33 PM
Thank you for the information.
Stewart vs Edelbrock Water Pump, Best of Both Worlds DTL504 Engine 5 04-15-2008 01:41 PM
Big block water pump on small block! TVR383 Engine 14 04-15-2008 07:43 AM
SBC 'Short' Water Pump vs Corvette Pump ezobens Engine 4 03-20-2006 10:36 AM
not enough of a water pump? TVR383 Engine 21 05-03-2005 07:48 PM
Water pump rotation question djenn Engine 6 03-07-2004 10:04 AM
