I want to remove the choke horn - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2003, 02:23 PM
cuda66's Avatar
Post I want to remove the choke horn
I was wondeing if there are any pit falls to removing the choke horn from a holly 750 with vac secondaries? What kind of tools should I use? I have a die grinder and a dremel tool. Are there any tricks? Joel
Old 04-01-2003, 02:32 PM
Post
No pit fall other than the obvious no choke. Be careful not to cut off the front air horn or the center threaded piece, have had friends get happy and lop that off hence no way to put on the air cleaner.
Old 04-01-2003, 02:35 PM
4 Jaw Chuck's Avatar
Post
Why do you want to do it? <img src="confused.gif" border="0">
— Han Solo
Old 04-01-2003, 08:18 PM
cuda66's Avatar
Post
Well I purchased a top shot nos kit and i am having problems with the instlation. Plus I currently have the choke screwed open and it is in the way!!!! I was also going to smooth it out and try to get a little more flow out of it! Joel
Old 04-01-2003, 08:37 PM
Post
The flow won't improve much but if you need the room the advice given so far will get you there. Tape every port and hole to prevent shavings getting in the carb passages, I've seen a few of these go bad beacuse the guy didn't take adequete precautions.
Good luck and post some pics!
— Han Solo
