I want to see your MII brake hose routing - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2012, 09:18 AM
Will I ever get it done?
Last journal entry: Passenger Door
Hi guys.
Please post some photos of your Mustang II brake hose routing. I don't want to reinvent the wheel. If you have a slick location that I can copy, I'm not proud.
Thanks.
Old 03-03-2012, 11:59 AM
the OE mustang II calipers have a different rubber brake hose port than the GM calipers common on 11" brake swaps. The GM port kind of points at the ford suspension. i'm looking for the early bracket that uses the pre '80 ford calipers. i'm sure they used to exist but i can't find them.
if i can't find the legendary "granada caliper brackets" i'll be finding another caliper.
Old 03-03-2012, 01:40 PM
daledove's Avatar
Check my gallery.
heater hose routing task65 Hotrodding Basics 5 10-19-2011 12:30 PM
Brake hose routing Q staleg Suspension - Brakes - Steering 4 03-12-2009 12:59 AM
Need Correct Coolant Hose Routing newdad1 Engine 1 09-02-2007 05:20 PM
Heater hose routing and hangers? Jag Daddy Engine 1 04-07-2004 03:22 PM
Vacuum hose routing diagram? 87442lover Engine 2 01-24-2004 08:08 AM
