Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 06-29-2005, 01:41 PM
pigman pigman is offline
id'ing a ford 9 inch with disk brakes
Hey all,
Im gonna start heading to local junkyards to see if I can find a ford 9" with disk brakes. Any one have a resource with serial numbers/pictures, so ill know it for sure when I see it?
Thanks
Mike
Old 06-29-2005, 02:46 PM
johnsongrass1's Avatar
johnsongrass1 johnsongrass1 is online now
Race it, Don't rice it!
re: id'ing a ford 9 inch with disk brakes
Drop out center section. Bottom nut will only take wrench, no socket. Beware the 8.8. It will take a socket.
Old 06-29-2005, 02:47 PM
KULTULZ's Avatar
KULTULZ KULTULZ is offline
aka Duke of URL
 KULTULZ's barnstar
You'll be looking for a late seventies LINC VERSAILES, FORD GRANADA or MERC MONARCH (last two hi-trim) to find a complete asm.
Also seventies big LINCS will have rear disc with the 9".
What are you retrofitting?
Old 06-30-2005, 05:58 AM
it's going to be going into a 1970 mustang, it was equipped with a 9" before, but i'd like to go to a disk setup, and will be installing either a 3 link w/ coil overs or a triangulated 4-link with coil overs.
It seems like it would probly be easier to find one with disks then to convert the one i have, seems pretty hard to find a good kit for it at a reasonable price.
Mike
Old 06-30-2005, 08:08 AM
KULTULZ's Avatar
aka Duke of URL
 KULTULZ's barnstar
Mike
Well....
There are links here on the Knowledge Base that will give you the widths of individual axle housing assemblies.
About the only thing you will find with discs mounted will be the VERSAILLES rear asm and they are becoming scarce and service parts for the system hard to find.
I personally prefer the MARK VII/SVO rear disc setup and adaptors are available to bolt them on the 9" axle ends.
Read this -REFERRING URL- and see if it will help.
Old 07-05-2005, 07:41 PM
flathead flathead is offline
'48 F1
Hi Pigman,
Nice name, I'm also a farmer, Walnuts, Apples and Cherries, here in the central San Joaquin Valley of Calif. I'm putting AirRide bags on a '48 F1 PU that I bought in '63 from the original owner and has been stored since then. I switched the rear springs from the outside of the frame to the inside to give more room to mount the bags. What I need is a set of flanges that go under the axle and that the spring u-=bolts go through to hold the springs to the axle. The plate I'm looking for also has a shock mount on it. I saw that you're going to change to a 9" rear end which has a 3" tube so I was wondering if you would consider selling your old one as it is 2.5"?
Old 07-05-2005, 09:03 PM
KULTULZ's Avatar
aka Duke of URL
 KULTULZ's barnstar
Will -these- help?
Old 07-31-2005, 12:55 PM
xntrik's Avatar
xntrik xntrik is offline
Save a horse, Ride a Cowboy.
id ford 9" with disk brakes
Mike
Versailles 9" = Generally speaking they are getting pretty scarce, and when you find one they bring $ 600 easy. I used to buy driving Versailles and swap out the disc 9" and install a Granada 8 " (a direct drop in) and then resell the car for as much as I paid for it. Another thing to consider is the 80 Monarch high-line, some had 9 in disc brakes, some had the 8.8 (yes, an 8.8 on leaf springs) though I have seen only two. The Versailles rear end has been popular, though the brake repair parts are hard to find (but getting better), not as well designed as aftermarket, and the failure prone parking brake lever has not yet been reproduced as far as I know. If you can find a good set up, do it. If not, spend the $ 700 on a good aftermarket set up. Also the Versailles is 57 1/2 inches wide which is excellent for the 70 Mustang because it is 2 inches narrower (depending on which 70 stang, yes they varied) which gives you more tire clearance.
9 inch rear ends have two different bolt patterns (3 if you count the trucks) that hold the wheel bearing/axle into the housing, so obviously the disc set up must match those. Be careful too, if adapting a disc set up onto your existing rear end, that the distance the axle wheel face is from the end of the housing varies, and some factory disc set ups that bolt to your housing will not place the caliper in the proper place with your axles.
All in all.... go aftermarket if you absolutely need the disc brake "look".
You say you are spending $$$ changing the rear suspension, but don't know to what type, so obviously you don't know what purpose you are going to use the car for or do not understand suspensions. I don't know why you would want to change the rear suspension anyway, the leaf set up is excellent and needs only minor tweaking to do whatever any street car needs. Since you have the money to change all that, the price of the discs brakes should not be a consideration anyway. Just being realistic.
Old 08-26-2005, 06:39 AM
willowbilly3's Avatar
willowbilly3 willowbilly3 is offline
The only factory 9 inch with discs comes off the 70s Mark 4 amd 5 and some big town cars. You might use it under a 70 mustang with some special wheel off set but as mentioned it will be too wide, and it will have the 5 on 5 pattern, not the 4 1/2.
The 8.8 is a rear loader and is easy to tell from an 8 or 9 inch. Really the 8.8 from a Versailes would be a fairly stout rear end unless you want to run like niteous and slicks.
You might consider an Explorer rear end brake set up converted to your existing axle. I have seen how-to articles on this conversion.
Old 08-26-2005, 07:08 AM
packnrat packnrat is offline
9in disk
if you want a stock set of disk brakes, i have a set off of a 1977 (as i was told) Lincoln, with two brand new rotors, car bolt pattern of 5 on 4 1/2.
the calipers need rebuilding, the rotors have never been used, comes with mounting brackets, complete set, you supply the bolts. i would have to get the length of the axles shafts they are 28 spline but can sell them to you if you like.
packnrat
packnrat@lycos.com
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "id'ing a ford 9 inch with disk brakes"
Ford Lincoln Rear Disk brake help TurboS10 Transmission - Rearend 7 10-03-2006 09:09 AM
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 9 03-08-2005 08:23 PM
9 inch Ford Rear End Larry Day Transmission - Rearend 4 02-11-2004 08:27 AM
10 bolt 7.5 to ford nine inch big455 Transmission - Rearend 4 10-28-2003 07:34 PM
Ford Explorer Rear Disc Brakes Lloyd Topping Jr Transmission - Rearend 4 11-10-2002 02:06 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
