ID make & Model of donor car in a Street Rd - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2012, 06:22 AM
The car is a backyard Build, which I am making into a transmorfing into some subclass of a woody. I am trying to figure out what year and make vehicle it came out of, I need Motor mounts and some other Parts.
So far I have identified the block a 230 1965 Built in Flint Michigan Dec 7 1964. This conflicts with the info the machinist gave me that the head was a 250, so maybe someone changed the head out to something different? At least that is what the machinist told me who rebuilt it and re-ground the cam, What he didn't do is put the lump ports in which i am thinking of having done now.
Always looking to add more HP/Torque. It has a 2 speed powerglide (completely rebuilt) in it. I has all new rings, pistons, valves, pushrods, and crankshaft. cylinders bored out .030 over,.010 off the block and the head was angled but I don't recall what degree. It has an Offenheimer 4BBL intake with Stovebolt headers. I am running what I believe to be a 600(?) edelbrock, to me it is mounted sideways with the edelbrock tag facing the valve cover. The story goes It was done this way as there was not enough clearance for the Linkage on the side f the carburetor. I have a 6” lift tunnel for it, will see what that does in the spring.
My future issue to resolve after I fing out what this came out of is: on takeoff although it pulls right off the line, it seems like there should be some tire burning, at least chirping and more torque (machinist was guessing I would have about) .85-.9 Hp for every CC, which would put me about 215 HP.
For the Block:
By the distributor is the # F1207FA
Above the starter on the block is the # CON2 on 1 tag and L34 on the other
on the head are the#'s 4886X, in one spot and 4883 15 in another.
It has a silver Chevrolet tag on the body with the # B56J168735, I have pictures if it helps of the steering wheel and center console, along with the pics of the #'s.
Any Idea’s you have on ID ing the model car this come out of would be appreciated.
Bill Toothaker
ID:	69090   Click image for larger version
ID:	69091   Click image for larger version
Name:	Steering Wheel.JPG
ID:	69092   Click image for larger version
Name:	Fuel Filter 2.JPG
Old 11-12-2012, 06:32 AM
poncho62's Avatar
Wiki Edits: 5
What is the logo in the centre of the steering column?....Lots like a mid 60s GM to me.
230 and 250 Chevy six were basically the same engine
Ontario Rodders
Old 11-12-2012, 07:33 AM
ID Donor car
Ponco62,
Here is the steering cap and more console pictures, i was hoping the console would give it away, someone would recognize it.
I think we figured at least the block was made 12/7/64, i have gotten conflicting infor on the head, the Block casting # shows is was done as a 230, but my machist said it was a 250 and rebuilt it as such, Which all doesn't really matter I need to figure out what model (s) of car it was in so I can narrow down the options to get replacement motor mounts.
thanks for your input!
Cheers!
Name:	Steering wheel center hub.JPG
ID:	69095   Click image for larger version
ID:	69096   Click image for larger version
Old 11-12-2012, 07:39 AM
More Photo's
Old 11-12-2012, 07:40 AM
poncho62's Avatar
Wiki Edits: 5
I am guessing 64-65 Chev Impala....Seeing as the engine checks out as a 65, I would be leaning that way
Ontario Rodders
Old 11-12-2012, 07:46 AM
gearheadslife's Avatar
MentalMuffinMan
Originally Posted by BillToothaker View Post
Ponco62,
Cheers!
1965 c-10 230cid l6 mounts
1979 camaro 250cid l6 mount
maybe the mounts on yours looks like one of these..
iirc the top photo type is called a bisket and the bottom (camaro ) a clamshell
Old 11-12-2012, 08:33 AM
Motor Mounts
In taking Pictures of the Motor Mount (with my glasses on-should wear these more!) there is a part number on the rubber 37-2404 - some symbol-1-4, Will will search this.
I have attched pictures still maybe someone identify it.
Name:	Motor Mount 1.JPG
ID:	69101   Click image for larger version
Name:	Motor Mount 2.JPG
ID:	69102   Click image for larger version
Name:	Motor Mount 3.JPG
ID:	69103   Click image for larger version
Name:	Motor Mount 4.JPG
Old 11-12-2012, 08:44 AM
poncho62's Avatar
Wiki Edits: 5
Just go to NAPA and ask for a motor mount for a 65 Chevy with a six cylinder....Betcha thats the one....Take that one with you to compare
Ontario Rodders
Old 11-12-2012, 08:58 AM
ID Donor car
I will take it back down now that i at least have a year to go by- I went before but didn't know if we were looking for 60's or 70's, I will try an impala first, and a partial part #.
Thanks Again, go through this again when i need brake shoes.
RWENUTS's Avatar
I think you're trying to buy the cart before the horse.
The motor mounts are the least of your worries. Looking at the rest of your pics I wonder how you plan on getting that death-trap licensed for the road.
JMHO
Old 11-12-2012, 09:10 AM
NEW INTERIORS's Avatar
Set no limit's on yourself
The console looks like a 60's chevelle console..As far as the body, That look's to be homemade..
Old 11-12-2012, 10:01 AM
poncho62's Avatar
Wiki Edits: 5
I think you are right Randy......Either way, I think the 6cyl motor mounts would be the same
Ontario Rodders
Old 11-12-2012, 10:12 AM
MentalMuffinMan
console looks like impala mid 60's
tiller, also, but both could be chevelle parts,,
can't tell by the pic if the rear end has 2 upper links or one..
if brakes are 9x2 drums(rear) good chance it's a body parts, 11" think full sized,, looks like someone had a donor car, and used the rear crossmember for the rear end mounts, etc
Old 11-12-2012, 10:19 AM
I think so Poncho.. I don't think they made a lot of different mounts back then for the 6cyl motors..
I was holding a console just like that one this past Sat.. Talking about installing a 3'' Tach in it.. For my friends 66 Chevelle..
Old 11-12-2012, 10:48 AM
I am looking at some restoration sites for Impala & Chevelle, thanks guys! I have looked at the impala, but the shape of the console isn't quite right and the steering wheel is off- On to the Chevelles~!
Model A Donor For Master Cyl. bluestang67 Suspension - Brakes - Steering 3 03-10-2007 11:09 PM
OEM Remote Battery Jumper Terminals-Make,Year & Model? acr Electrical 2 01-12-2007 11:00 AM
Donor Car for Seats for a 29 Model A babailey Interior 10 07-07-2006 09:13 AM
Stores to buy chassis & parts Model A Street Rod? Fortingo Suspension - Brakes - Steering 4 09-18-2003 08:59 PM
What car (make and model) can be use to place a Model A body? Fortingo General Rodding Tech 7 05-10-2003 03:25 PM
