ID this master cylinder? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2013, 12:40 PM
Just got this hotrod, 37 Chevy coupe.
Brakes will stop the car in the driveway but no way Im driving this thing...
Brakes are way too weak and slow to stop the car...
Can anyone ID this master cylinder?
I think it may be from the S-10 family.. and the builder converted it to a remote resivoir which is in the trunk.........
Rear end is a 88 S-10 Posi, the shoes, drums, springs etc all look brand new.
Front is the typical Mustang II set up... pads look fine...
Low pedal and very little stopping power...........
I know theres some pressure to the rears cause the brake light pressure switch turns on the brake lights... and while under the car I can pull down on the pedal and feel the resistance in turning the drivers front wheel...
any advice?
Will ad a couple more pics in the following post.
Craig
ID:	75573   Click image for larger version
ID:	75574   Click image for larger version
ID:	75575   Click image for larger version
ID:	75576   Click image for larger version
GM master cylinder ? lanierledford Suspension - Brakes - Steering 1 03-06-2010 01:31 PM
master cylinder 87MonteCarloSS Suspension - Brakes - Steering 2 09-04-2009 07:32 AM
Master cylinder evenmore Hotrodding Basics 1 01-26-2009 08:06 PM
which master cylinder? stea Suspension - Brakes - Steering 15 12-22-2003 07:14 PM
Master cylinder fred56 Suspension - Brakes - Steering 2 10-15-2003 11:04 AM
