ID my 9 inch ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2009, 07:33 PM
ID my 9 inch ford
Here are some pis of my 9 inch third member can anybody ID it for me my web searched have not turned up much.
Old 02-27-2009, 07:44 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
maybe this can help.looks to be out of 60 model car.its just your standard 9 in but still a good case.ford rear end indentifer cole
Old 02-27-2009, 07:46 PM
kleen56's Avatar
The numbers on the case "C0" means it's probably a 1960 Ford, looks like a 9 inch ford 3rd member. Might be from Galaxie or similar type vehicle. It states 3.89 gears. To check the ratio, count the number of teeth on the ring and pinion and divide the two. 40 teeth divided by 10= 4.00 gearing. It also appears to be an open rear end, more than likely a 28 spline which was common.
Old 02-27-2009, 08:16 PM
It came out of a truck housing that was in a truck, the ring gear was been previously removed, I can see marks on the case where the socket left small "tool" marks. I thought it was a open carrier but when I spin the yoke both axles move the same direction so I'm thinking a mini spool was added So how is this compared to the WAB or the WAR case, and the nodular cases? This third member will be going into a 1957 nine inch housing that will be going int my 63 Chevy II sedan gasser.
Thanks for the help.
Old 02-27-2009, 08:22 PM
eloc431962's Avatar
Wiki Edits: 37
its a 9 in ford its a good case.its just your standard 9in its not as strong as the N case or the war.but still a good one. cole
Ford Bolt Pattern 4.25 inch? 31fordcoupe Suspension - Brakes - Steering 21 10-29-2009 03:44 AM
ford 9 inch in a 72 Camaro Zanzahl Transmission - Rearend 2 02-23-2009 05:20 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 06:29 AM
10 bolt 7.5 to ford nine inch big455 Transmission - Rearend 4 10-28-2003 08:34 PM
disc brakes for ford 9 inch Beedog69 Suspension - Brakes - Steering 6 06-04-2002 04:18 PM
