id rear end? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2006, 06:02 PM
id rear end?
is there any sites that will id my rear end . 12 bolt came out of 72 73 cutlass 4 link. put in chevelle. the numbers i found were on the front near the drive shaft. 402227 cfd5
dont think it is posi. but if i turn left and stomp on the gas it will get side ways but i turn right it will just smoke the right tire. why does it do this?
Old 04-17-2006, 06:35 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Open differentials will do wierd things like this.
What all do you want to know about the axle?
Give me the stamped number on the front of the passenger side axle tube, I can give the most info off from that.
Old 04-17-2006, 06:54 PM
i looked for a number but didnt find it on the tube but there were numbers on the front near the drive shaft/
Old 04-17-2006, 06:57 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
What all else do you want to know about the axle?
It sounds like it's a 8.5 inch 10-bolt. They discontinued the 8.2 a couple years before that.
The peculiarity of it spinning wierd, could also be caused by a severly work clutch style limited slip differential too.
Thump Thump in rear end?? HotRodMan Suspension - Brakes - Steering 7 01-24-2007 06:09 PM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 05:32 AM
Rear End Change black66 Transmission - Rearend 4 01-28-2004 09:21 AM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 06:05 PM
Ford 7.5" Rear End Traction-Loc Install nightrain_rod Transmission - Rearend 2 12-30-2003 06:38 PM
