ID some GM 12 bolt numbers please - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2011, 05:14 PM
OK i just got this rear end from a guy and the numbers from the side of the rearend are 14055251 and then there is either a g54 or c54 on the neck ... can someone help me with this it is a 12bolt 5 lug rearend..
Old 03-10-2011, 05:33 AM
Crosley's Avatar
Wiki Edits: 1659
bump this up
Old 03-10-2011, 06:02 AM
ericnova72's Avatar
More for Less Racer
Need the numbers stamped into the forward side of the axle tube. The numbers you have posted are just casting #'s for the centersection and won't identify the rear end.
12-bolt car or 12-bolt truck rear?? Can you post a picture of it?? How wide is is from wheel mounting surface to wheel mounting surface??
Old 03-11-2011, 01:11 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
It appears the same casting numbers were used on both 10- and 12-bolt truck rear ends. The reference I saw on the 12-bolt was that it was in a '84 Suburban.
Engine casting numbers and vin numbers drfo Engine 5 06-18-2010 05:15 PM
8.5" 10 bolt ring gear numbers sherman8r Transmission - Rearend 2 02-09-2009 04:37 PM
GM 10 bolt Diff ID numbers? Gearhead forever Transmission - Rearend 8 04-27-2005 08:45 AM
gm 10 bolt id numbers 47dawg Transmission - Rearend 2 10-17-2003 05:39 PM
2 bolt to 4 bolt swap and 2 bolt strength???? HemmiGremmie Engine 8 10-20-2002 03:06 PM
