ID Transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2011, 09:29 AM
ID Transmission
I have a early ford tranny hooked up behind a 1956 Buick Nailhead and am trying to figure out what year it is. It has a casting number of H633305A and a stamped number of 13130984. Would appreciate some help.
Old 12-09-2011, 05:30 PM
Wiki Edits: 27
pict's
A couple of picts would point us in the right direction.
Old 12-11-2011, 10:37 AM
Wiki Edits: 85
Your numbers don't help as the first appears to be a misread 1987 VIN number and the second appears to be a serial number, neither of which helps.
Find the tag on the transmission and give us those numbers. And/or post a pic. And/or post the casting numbers on the transmission.
You could also go here (http://www.crankshaftcoalition.com/w..._Transmissions) and see if that helps.
Old 12-11-2011, 04:18 PM
Wiki Edits: 27
what's early
back when we did a lot of engine-trans swaps you would use the trans that came with the car and an adaptor plate. Is the trans one with the stick shift as part of the top case, , a side shift cover for a column shift. Does it have a torque tube drive or open drive shaft, Is it a lincoln T 85, merc, bolt on rear adaptor for torqu tube.. A lot more info is needed
transmission pan?? doughboyman66 Transmission - Rearend 5 11-23-2009 09:34 AM
*Transmission Help* which one is it???? 76ChevyNova Transmission - Rearend 5 07-21-2006 03:18 PM
Transmission??? 85cutdog Transmission - Rearend 1 05-10-2004 03:32 PM
Transmission JMac19 Hotrodding Basics 3 10-01-2003 12:58 AM
Which transmission to keep/run? wesblake Transmission - Rearend 6 03-13-2003 06:53 PM
