-   -   ID this transmission? (http://www.hotrodders.com/forum/id-transmission-92650.html)
oldguy829 06-28-2006 12:56 PM
I have a TH350 that I think is early 80's the only numbers i can find are 50
and below that 8640300. Can anyone help? thanks.
Chazmac 07-01-2006 09:06 AM
Pictures??
Is there an electrical connector on the drivers side of the trans above the pan gasket area?
Overall length?
fast68 07-03-2006 06:09 PM
length isnt going to tell us anything to do with the age, all four lengths were made all years '69-85
around 1980 there was a BOP fits all case pattern and lockup converter, but thats the only external things changed over the years
it doesnt really mater what year it is anyways, what is more important is what application is came from, IE how strong the internals and packs and such are,
if it was behind a v-6 or small v-8 then it will need work and $ spent on it to be trustworthy behind any larger engine
also whether it is a 60 degree or a 90 degree housing
if 60 degree then its about useless except behind 4 cyl and most 6 cyl engines
good luck
tnsmith10 07-05-2006 08:11 AM
good luck
have u got any pics of a 60 degree bellhousing th350??? if so, id love to see them... btw., the 700r4 came out in 82, so who says its not a 700r4?
oldguy, can u produce a pic ot the trans please? we can help u figure out what it is...
