ID this transmission? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2006, 11:56 AM
oldguy829's Avatar
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
I have a TH350 that I think is early 80's the only numbers i can find are 50
and below that 8640300. Can anyone help? thanks.
Old 07-01-2006, 08:06 AM
Pictures??
Is there an electrical connector on the drivers side of the trans above the pan gasket area?
Overall length?
Old 07-03-2006, 05:09 PM
fast68's Avatar
likes chevy trucks & boobies
length isnt going to tell us anything to do with the age, all four lengths were made all years '69-85
around 1980 there was a BOP fits all case pattern and lockup converter, but thats the only external things changed over the years
it doesnt really mater what year it is anyways, what is more important is what application is came from, IE how strong the internals and packs and such are,
if it was behind a v-6 or small v-8 then it will need work and $ spent on it to be trustworthy behind any larger engine
also whether it is a 60 degree or a 90 degree housing
if 60 degree then its about useless except behind 4 cyl and most 6 cyl engines
good luck
Old 07-05-2006, 07:11 AM
tnsmith10's Avatar
when will it rain???
good luck
have u got any pics of a 60 degree bellhousing th350??? if so, id love to see them... btw., the 700r4 came out in 82, so who says its not a 700r4?
oldguy, can u produce a pic ot the trans please? we can help u figure out what it is...
94 Dodge Transmission Electronics problem? Native Gearhead Transmission - Rearend 7 10-17-2006 10:00 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 06:23 PM
transmission oil type. TVR383 Transmission - Rearend 3 06-05-2005 09:28 AM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
83 Z28 Transmission - YIKES! crandaz28 Transmission - Rearend 4 11-25-2003 07:43 AM
