ID this trim? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2008, 09:58 PM
ID this trim?
Attached is a pic of a pair of pin retainer/upostery protectors I pulled out of my truck after a pass under the wire wheel. I know that they are not original to the truck, they are actually too big in the center for the door handle and window crank, but I think I could work with them. Question is... What did they come off of? They are spring loaded, with the center 'dome' part retracting into the ribbed base. Any help? EDIT... I need two more
Old 05-25-2008, 04:39 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Unkamort....not sure what they are off of, ut I know the older Fords and probably others that had one similiar also had a plastic style washer on top that would be the size of the top dome and then have a recessed area that waent into the larger hole. Then the hole in the plastic part was not much larger than the part protruding from the regulator. I have a box of old handles and such in the attic i will go through in a little while.
Old 05-25-2008, 11:43 PM
Thanks! Even if you don't want to sell, finding out what to look for would be a big plus.
Old 05-27-2008, 03:44 PM
I don't think it's exactly the same, but something similar is used on '55-6 Mercury hardtop quarter window regulators, I couldn't say for sure on Fords but probably on Crown Victorias, and it is quarter window only, not used on the front door window cranks.
Old 05-28-2008, 03:58 PM
Sounds a little odd... not matching 1/4 window and front window cranks, but I'll take your word for it. Should have paid more attention when I was a kid... If I even knew that its been loooooong forgotten.
Old 05-31-2008, 11:04 AM
9 day bump... still looking for info on these parts. Thanks
Old 06-04-2008, 05:32 PM
found'em!
Just a note to add to the general information pool... The trim pieces are for a 40 Ford. I found them at Scramento vintage Ford. Thanks to all who replyed!
custom exterior trim impache Body - Exterior 0 10-09-2007 11:52 PM
How do I remove widsheild/rear window trim from 65 GTO without damage? smallblocker2 Body - Exterior 10 06-25-2007 12:40 AM
69 bonneville vinal top belt trim removal question Bad Rat Body - Exterior 2 02-26-2007 02:32 AM
Rubber Moulding Trim Needed... bg Body - Exterior 10 09-10-2006 10:14 PM
70 el camino under rear window bed trim removal hrd Body - Exterior 0 03-25-2006 12:11 PM
