Id this truck and straight axle? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2010, 10:19 AM
Hey guys/gals im guessing this is a 61-62 ford truck, it looks like a 3/4 ton, not sure, is this a straight axle front end and if so can it be used for a gasser front end on a 55 chevy? I know alot of rodders used van front ends and was just wondering if this one would work? thanks..
Old 06-13-2010, 11:17 AM
powerrodsmike's Avatar
Wiki Edits: 161
61 Ford unibody, even if it's a 1/2 ton I think the axle is a poor choice for a gasser. Too wide and heavy and the wheel bolt pattern is 5 on 5.5.
The kinda popular ones were 61-66 Econoline vans.
I'd check speedway motors, they have some economy straight axle kits for that car.
Later, mikey
BE different....ACT normal.
Old 06-13-2010, 11:37 AM
thanks ill look into that
56 chevy truck straight axle lowering mike's hotrods Suspension - Brakes - Steering 12 06-29-2010 01:30 PM
front straight axle on 32 ford model b truck BonnevilleBrat Suspension - Brakes - Steering 6 01-28-2009 11:00 PM
1950 F1 Straight axle disc brakes power steering lelshaddai Suspension - Brakes - Steering 1 05-21-2008 02:35 PM
Thinking about building a custom straight axle front suspension toddshotrods Suspension - Brakes - Steering 9 10-24-2007 08:29 AM
Jeep mail truck straight axle question MiMAX Suspension - Brakes - Steering 12 04-10-2006 12:13 AM
