-   -   Idea about cooling compressor line temps (http://www.hotrodders.com/forum/idea-about-cooling-compressor-line-temps-186746.html)
chevymike 10-28-2010 04:06 PM
Okay, so I got this idea after I was watching Two Guys Garage and thought someone here might be able to confirm or denie an idea I have.
My thought was to put an A/C condenser in the air line system from the output of the compressor. I would mount a fan that would blow air thru the condenser to help cool the air moving it. Kind of like an intercooler for a turbo.
I typically have my compressor output set to 110-120 psi so my question is, would an A/C condenser handle this pressure and would this idea work for cooling the output line temps before running thru a water trap/filter?
Thanks
302 Z28 10-28-2010 05:20 PM
The AC condersor will handle the pressure with no problem at all. Your idea is sound.
Vince
NEW INTERIORS 10-28-2010 07:14 PM
1 Attachment(s)
You can buy these to put on your Compressor.. ;) Some compressors come with them now.. ;)
shine 10-29-2010 05:01 AM
i am moving my compressor up the hill from my shop. i will bury the line coming to the shop and do a field something like lateral lines. let the ground cool the air before it comes into the shop. will have a moisture trap there. a/c condensers work well and can hold 400 lbs .
chevymike 10-29-2010 10:43 AM
That picture almost looks like a transmission cooler. Any details on that or would a transmission cooler work? I was thinking they were more for liquids where a car A/C condenser had gas thru it.
Trying to do this low buck.
shine 10-29-2010 11:04 AM
i would use a large tube and fin cooler for volume. avoid a/c condensers that may chock down you flow.
NEW INTERIORS 10-29-2010 12:07 PM
Here's where you can get one.. ;) http://www.alltiresupply.com/p-AB20MTD.html
chevymike 10-29-2010 01:20 PM
Thanks for the info. Definitely more than I want to spend but it did give me some good search info and I found this,
http://www.grainger.com/Grainger/Air...JG4?Pid=search
About half the price and looks like it has good flow numbers.
Thanks agian for the info everyone.
NEW INTERIORS 10-29-2010 02:13 PM
:thumbup: :thumbup:
