Idea about cooling compressor line temps - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-28-2010, 04:06 PM
chevymike's Avatar
Okay, so I got this idea after I was watching Two Guys Garage and thought someone here might be able to confirm or denie an idea I have.
My thought was to put an A/C condenser in the air line system from the output of the compressor. I would mount a fan that would blow air thru the condenser to help cool the air moving it. Kind of like an intercooler for a turbo.
I typically have my compressor output set to 110-120 psi so my question is, would an A/C condenser handle this pressure and would this idea work for cooling the output line temps before running thru a water trap/filter?
Thanks
Old 10-28-2010, 05:20 PM
302 Z28's Avatar
The AC condersor will handle the pressure with no problem at all. Your idea is sound.
Vince
Old 10-28-2010, 07:14 PM
life is a temporary assignment
You can buy these to put on your Compressor.. Some compressors come with them now..
Old 10-29-2010, 05:01 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
i am moving my compressor up the hill from my shop. i will bury the line coming to the shop and do a field something like lateral lines. let the ground cool the air before it comes into the shop. will have a moisture trap there. a/c condensers work well and can hold 400 lbs .
Old 10-29-2010, 10:43 AM
chevymike's Avatar
That picture almost looks like a transmission cooler. Any details on that or would a transmission cooler work? I was thinking they were more for liquids where a car A/C condenser had gas thru it.
Trying to do this low buck.
Old 10-29-2010, 11:04 AM
shine's Avatar
SPI Thug
i would use a large tube and fin cooler for volume. avoid a/c condensers that may chock down you flow.
Old 10-29-2010, 12:07 PM
Here's where you can get one.. http://www.alltiresupply.com/p-AB20MTD.html
Old 10-29-2010, 01:20 PM
chevymike's Avatar
Thanks for the info. Definitely more than I want to spend but it did give me some good search info and I found this,
http://www.grainger.com/Grainger/Air...JG4?Pid=search
About half the price and looks like it has good flow numbers.
Thanks agian for the info everyone.
Old 10-29-2010, 02:13 PM
Q-Jet Metering Rod Idea Silver_Camaro Engine 6 09-16-2003 01:48 PM
Whacko Idea! Need transmission unstable Transmission - Rearend 5 06-26-2003 08:51 PM
Idea for a new carb...? Bartman39 Engine 5 05-13-2003 05:13 AM
Trunk idea Wmarden Interior 13 11-07-2002 11:11 AM
Cooling Help Please. F-1Rodder Engine 2 09-06-2002 09:18 AM
