idea for cheap respirator air supply... - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2004, 03:46 PM
deuce_454's Avatar
i am tinkering arround with a couple of smog pumps and i got the idea of using one (throughly cleaned) to supply clean outside air through a 1/2 inch pvc hose to a mask (the pressure hose to the paint gun could be strip tied to the air supply hose to minimize clutter) so a coulpe of used filteres to my 3M mask gerryrigged to accept the hose from the smog pump should do the trick (that way excess air should simply blow through the exhaust valve, and not blow my lungs)
inputs anyone???
Old 04-06-2004, 06:06 PM
daimon1054's Avatar
A SCUBA tank is only $140 and to fill them is $3. If you have a mask you could rig something up using that.
Old 04-06-2004, 06:44 PM
302 Z28's Avatar
A firm near my home that specializes in breathing air for industry will rent me a six pack of breathing air bottles for a one time charge of $45. These bottles are the size of acytelene bottles and are pressurized to 2100psi. Six of them will last a very long time when used with one mask. A side benefit is it is certified breathing air.
Vince
Old 04-07-2004, 02:19 AM
deuce_454's Avatar
the reason i thought of it is that a smog pump usually costs between 5 and 30 bucks at a junk yard and you have the hose for the paint gun cluttering the floor anyway. ill try and rig it together and post some pics soon.
Old 04-20-2004, 08:51 AM
Deuce,
I know I am late responding to this thread, but thought it might give you an idea.
What about using the compressed air hose that comes in a plastic material and coiled up? It is very light, you can use comp. air couplings at the end for quick disconnect and hang the hose at the ceiling of your garage (paint booth) to avoid the cluttering? (you have seen the movie the "Outbreak" - they have those chemical protection suits constructed in the same manner :-)
Smog pump idea is a good one. How much pressure (psi) can a smog pump generate? Would it be adequate for your breathing needs?
Regards,
Denis
'67 Camaro RS
