Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Idea thread: Planning my semi-permanent paint booth, hoping for your input
  #40 (permalink)
Old 04-17-2013, 09:29 PM
Lizer Lizer is offline
I scored a free fan from an old body guy that used it in his home garage to spray. He took a squirrel cage furnace blower and put it in this enclosure with filtered inlets on the top and front. It's belt driven by the motor on the side there.
Is this type of AC motor brushless? He just sprayed with the entire thing in the room, and had ducting that took it out the roof. I'll run my ducting out in a similar fashion.
Second, do the cheapie utility lights with exposed bulbs have issues with the bulbs getting coated and covered in overspray?
Third, I'm trying to figure out how to mount the lights on the side walls in terms of running power to them. The lights will have a cord that plugs in. If there were actually outlets in the booth for the lights to plug into--and outlets either had a light plugged into it or one of those outlet baby-proofing protectors you plug into it, would this present a serious risk? I ask because people mention plugging lights into extension cords and this is the same thing, it's just an outlet, not extension cord.
