For ventilation, past threads have talked about it's best to have fans supplying fresh air (clean shop air?) and the paint air exiting through external filters but without fans. Would the air supply fans be best if they were mounted on the ceiling providing a down draft or in a side wall blowing across? To exhaust air, I'd probably crack the door the width of a filter, build a 2x4 frame and run filters all the way up.
For lighting I was wondering if 4 of those cheapie $10 4' fluorescent light fixtures you can get from Lowes on the ceiling are sufficient, or if I should have lights on the side walls too? Also concerned about how I should run power to minimize explosion hazards. |
As far as lights go with as many as you can afford, you can't have too much light when painting.
If you can't place the compressor outside or in another room, at least place it as far from the painting area as possible.
1. As Milo said, you don't want airborne oil droplets floating around. 2. The pressure switch contacts arc when turning on and especially off. 3. The compressor cooling pulley stirs up dust. 4. Lights on the walls are great, especially when trying to paint down along the rockers. 5. Have a dedicated compressed air outlet just for painting, no air tools. Get a good water separator and use all 3/8 ID hose and fittings. I've made about every mistake possible so what I know, I learned the hard way. The pros will have more and better ideas. regards ron |
If you plan to insulate I would do that first.. Then either Sheetrock and tape ceiling or go paint tin.I sheet rocked mine and now wish I had went with the tin. May try to tape and paint my ceiling and do the walls with ceramic tile some day.Thought I had plenty of lights and still wish I had more. Made it a semi cross flow. Fan in front at filters pulling down from filters in ceiling at the rear. If anyway possible I would try to move the compressor. Not only because of the oil concerns which dosen't seem to be that big of a problem if compressor is in good shape. But when it comes on it does strange things to the air flow in the booth.I posted a picture of mine. It's just used to paint in and if I dont have anything a paint I will sometimes just park a car in it.
A lot of comments about moving the air compressor. Right now the compressor is just sitting on the pallet (and that's how I've always left it) so it can easily be moved. It's a newer compressor--I've had it two years. I'm starting this thread now because I'm going to be running the power to the compressor and am debating on where I put the 220 outlet. The fact that I'll probably be moving my compressor when I paint will affect this decision. I'm not ambitious enough for drywall, my current plan was to take some particle board, prime it and paint it, and put it up there? I want all the surfaces at least painted so I can hose it down to clean it. I should have prefaced this with we just bought the place and are putting money into it in lots of places (you know, those things called priorities ). Needless to say this ranks low on the priorities (or at least I have to make it seem like it does Can you go into more detail on your flow? I'm a little confused. |
Know all about that budget thing. Talked the wife into us taking a loan to build my shop and went way over budget. She was not a happy camper. I've got about $65,000 into it and its still not completely done. It's only 30x60 and I did all the inside work myself. As to the flow in my booth the intake filters are at the back of the booth in the ceiling. The white filter in the pictures. The outlet is at the floor in the very front. The green filters in the pictures. I have a 24" old binks paint booth fan mounted outside pulling air in and across the car and out. Iam still working on closing off the lights and sealing everything up. Not as nice as a bought paint booth but should do the job just fine when complete. I've included a shot of the fan.I'am going to try to get the exhust stack covered this summer with steel to match the building.I had to slow the fan down from where binks had it because it tryed to turn the building insideout.
Big Question. You said this is your shop area. Is it attached to living quarters (house)? If it is, you should use exhaust fans to remove the air from the spray area. If air is forced into the area, fumes will migrate to the rest of the structure.
I assumed you were plumbing in your compressed air outlets. I have my compressor in the opposite corner of my garage with 1/2" copper pipe around the top of my walls. I have 5 drops and the one in my painting corner is for painting only. My compressor is about 10 years old and passes a little oil when I run it hard. I have to have a water/oil separator to avoid fish-eyes.
I mentioned the 3/8 fittings because I was amazed how big a pressure drop you get with the HVLP guns. We all have to fight the budget battle, especially those of us who are married, regards Ron |
Is it pretty critical if the lights are sealed, mainly for the sake of not blowing up or is it really one of those Chicken Little scenarios? The fluorescent lights I was originally considering getting are just your standard cheap open bulb shop light. Want to be smart but practical.
| T-400, semi metallic waffle plates in stock rebuild...good idea or a bad one? | Big Buick | Transmission - Rearend | 4 | 07-18-2010 08:44 PM |
| ADVICE PLEASE: Semi-permanent Sandblast / Spray Booth Construction | Sanctifier | Garage - Tools | 5 | 03-03-2008 10:18 PM |
| Need input on custom chop idea | swoodard23 | Body - Exterior | 5 | 11-12-2006 12:06 AM |
| any idea of thread on SBC oil pressure take-off? | pcoghlan | Engine | 5 | 03-15-2006 09:42 PM |
| Semi Gloss Hot Rod Paint | glg97 | Body - Exterior | 2 | 02-18-2006 11:34 AM |
