Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ideal temperture thermostat for SBC?
Old 09-04-2012, 09:10 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
One hole always worked for me, as since the T stat doesn't seal around the plunger it acts as the secondary hole. If I did drill 2 holes at idle it wouldn't get hot enough to open, as the coolant flow through the 2 holes would circulate just enough coolant to keep it from getting hot enough to open.
