Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ideas for bending exhaust pipe
Old 06-24-2009, 11:24 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
Originally Posted by Mike H
Have fun getting by the trans crossmember on the drivers side. I have built quite a few crossmembers out of 1 5/8" tubing for the G bodys so they can get real dual exhaust on the car without going under it or bith pipes on the pass. side of the car.
The 64-72 Chevelle crossmember fits these cars very nicely(I've done this) after trimmimg a little length (less than an inch) off each end and redrilling the mounting holes. Bolt it up to the tranny mount then and square it up to see where you need to drill the new holes in the frame. This crossmember has two humps for dual pipes, and I believe the 73-74 Chevelle/Monte Carlo member could also be made to easily fit.
