Ideas for bending exhaust pipe - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-11-2011, 08:57 AM
PATH=$PATH\:/usr/local/bin ; e
Originally Posted by 71haulnazz
You can buy a tube bender at Harbor Freight for like $100 bucks. Just pack with sand and bend away. Real easy.
Ha ha that is funny show us some of the pipes you have done..
  #17 (permalink)
Old 07-11-2011, 09:20 AM
Those are PIPE benders. A totally different beast. They do bend tubing, but will kink it as the dies aren't the same as pipe is bigger OD. For tubing, some work on the dies is needed or the tube must be packed with sand.
  #18 (permalink)
Old 07-11-2011, 01:54 PM
Wiki Edits: 27
tubing bender
I worked at a company that made oem exhaust systems , mufflers and Misc parts for Harley, Our cnc bender used a mandrel (egg shaped internal dies on a SS cable) that was pulled thru the tubing as it was bent to give the smooth wrinkle free surface. a lot of the tubing had to be annealed and the weld in the correct position to get good pieces.
  #19 (permalink)
Old 07-11-2011, 06:11 PM
cool rockin daddy's Avatar
1.21 giga-watts???!!!!
Muffer shops do NOT do mandrel bending. As mentioned before, the inner radius will be pinched in cutting down on the cross area of your pipe. Same with that wonder bender for $100!
  #20 (permalink)
Old 07-11-2011, 10:02 PM
That was worth resurrecting this old thread, VERY intresting.
  #21 (permalink)
Old 06-30-2012, 02:44 AM
Re: Ideas for bending exhaust pipe
Hello..
The information you shared in the post related to the exhaust pipe is really very nice. I am glad I visited here and gathered so much facts related to it. I will look forward to it.
_________________
Have a look at************************************************ l] | [url*********************************************/url] .
Last edited by OneMoreTime; 06-30-2012 at 08:23 AM. Reason: Commercial Advertising
  #22 (permalink)
Old 06-30-2012, 05:02 AM
Irelands child's Avatar
Yes!! I know that this is an old thread, but since no one had posted photos of a home welded up exhaust, wanted to show one for 'posterity' and the next guy who looks.
Built from:
2.250 tubing - a 10/12 foot length
U and J bends from Summit
SS clamps and hangers
Flowmaster mufflers
~$225 for all the above
Then MIGed together
The only 'pro' done pieces were the clamped pipe seen at the H pipe and that was to 'blow out' the pipe size for slip fit for ease of disassembly if ever needed. That cost me the price of a coffee and donut break for the three guys in the Midas shop.
Dave W
  #23 (permalink)
Old 06-30-2012, 10:02 AM
1971BB427's Avatar
If I was doing an El Camino I'd just spring for the Summit dual kit at $209. It may need minor changes to make it fit, but it is way easier and closer than starting with just bent pieces of pipe.
Summit Racing SUM-680101 - Summit Racing® Header-Back Dual Exhaust Systems - Overview - SummitRacing.com
How to DIY Exhaust pipe bending ChrisMiddleron Engine 19 11-21-2012 04:35 AM
longer exhaust duration ? 383silverado Engine 5 05-23-2007 07:24 AM
Exhaust Pipe Sizing? 1ownerT Hotrodding Basics 6 01-03-2007 08:46 PM
New Exhaust and now the engine runs hotter... nsane Engine 4 10-16-2005 02:30 AM
Cutlass exhaust manifolds ChrisMiddleron Engine 9 09-27-2005 03:08 PM
