Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ideas on fixing warpage on vette bumper near mounting area
Old 01-25-2013, 08:29 AM
tech69 tech69 is offline
put up or shut up
Originally Posted by 69 widetrack View Post
In 1998 I did a 77 Corvette with the same problem, I was fortunate enough to have a large hot water tank with a temperature control (a friend of mine owned a chroming shop and they need hot water for rinsing) that I could drop the whole bumper into...when it came out I had 2 pieces of metal and body panel adhesive ready. I applied the body panel adhesive and the first piece of metal to the underneath of the warped bumper and put the other piece of metal on the top of the bumper and clamped the 2 together...let the adhesive cure, bolted it to the vette and it took minimal repair to the bumper after. I haven't seen the car for a few years now but I know it has lasted for over ten years....longer than the original.
Hope this helps Henry. The hard part here would be to find that tank.
Ray
nice! The metal strip thing sounds like a good idea. so it sounds like the bottom piece was adherred to the adhesive and left in there? that sounds solid! I'd rather do that then making some pos aftermarket bumper fit. less work
