Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ideas on how to get the phillips screws out?
  #17 (permalink)
Old 09-13-2012, 01:12 AM
Chevymon Chevymon is offline
If you have access to an arc welder you could lay a large flat washer over the screw head and weld it to the head of the screw, then weld a nut to the washer. That will give way more than enough torque to get those screws out. Excellent reproduction screws are available. A mig welder might work for this, but the arc welder gives a good jolt to help break them loose.
The Following 2 Users Say Thank You to Chevymon For This Useful Post:
hinges56 (09-13-2012), white72gs455 (09-18-2012)
