Ideas & Opinions : Placement of Truck Heater & AC Units - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2003, 03:52 AM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
Post Ideas & Opinions : Placement of Truck Heater & AC Units
1 - I bought an after-market heater/defroster replacement for my truck from Chevy Duty ... it's very cool looking and is gonna do a nice job of heating my truck.
2 - There's an *old* looking air-conditioner that was in the truck when I bought it 2 months ago ... I turned it on once or twice and it seems to be in good working order, but it's kinda beat looking ... it's also very large - 16" wide, 12" deep and 5" high.
3 - I would LIKE to put the heater/defroster unit as low to the floor as I can, and also as close to "center" of the cab as possible. Unfortunately that big ol' AC unit is in the way ... it's also too large to move to the right and place under the glove box.
Any ideas or solutions to suggest?
I'm thinking, buy another AC unit that's smaller and not so ugly - then I could mount it under the glove box, have a better looking interior and also have my heater where I want it. Anybody know where I can look at AC units on the web?
Thanks.
Alan Horvath
<a href="http://AlanHorvath.com/" target="_blank">http://AlanHorvath.com/</a>
Old 03-23-2003, 05:58 AM
awsum34's Avatar
Post
try www.hotrodair.com
Old 03-23-2003, 10:22 AM
horvath's Avatar
Post
Wow! Vintage Air sure has the options, eh?
THANKS, awsum34!!!
Alan
Old 03-23-2003, 09:23 PM
snkbyt's Avatar
ASE Master
Last journal entry: 52 Chevy for sale
Post
Check out Hotrod Air also, Just received one of theirs for my 36 3 window. But why can't you remove the old unit and install the new. Usually they don't have to be in the center. Thats what hoses and ducts are for. I have the Vintage air unit in my 52 Chev P/U with the defrost ducts and kick panel A/c ducts as if you need A/C in Alaska! Ray
Old 03-23-2003, 09:57 PM
horvath's Avatar
Post
Hey, snkbyt
I certainly could remove the old unit and replace it with the new ... I just *want* it placed more towards the center ... it's a visual preference as well as a practical one - the way the heater blows (left, right & front) and also, since heat rises, I want it lower, without it being in the foot-space area.
I did check out HotRod Air ... but I'm *real* excited about the under-the-seat and behind-the-seat models Vintage Air offers, and they're only $380, too!
I'm gonna call them today and ask some questions : Since my truck is already outfitted with air (compressor, etc.) I should only need to replace things that are IN the interior, right? I want to keep this operation as simple as possible.
PS - What a time saver this site is!!! I was hunting on the web for over an hour last night and found nothing but aggravation. I post a message here, and bingo! My pals who have been there and done that set me up in no time, flat!
<img src="graemlins/mwink.gif" border="0" alt="[mwink]" />
Thanks, HotRodders!
Alan
[ March 24, 2003: Message edited by: horvath ]</p>
Old 03-24-2003, 03:34 AM
EBlack36's Avatar
Rebuilt Excitment
Post
I have used vintage air in both my 36 Pontiac and 57 Chevy and they work great and you do not see either unit. In the 48 Chevy pickup I am currently working on I mounted the HVAC unit behind the dash where you can not see the unit by making a bracket that bolts to some of the stock braces that are already in there. Then you can put the vents were you want them, plus you get defrost and floor heat. You will lose a little of you glove box, vintage even has a sure fit in which you do not even have to drill a single hole, that is what I used in my 57. keep cool.
Old 03-24-2003, 04:53 AM
horvath's Avatar
Post
Thanks, EBlack36 - That sounds pretty cool!
How much was the HVAC unit you're referring to? And which model is it?
I'd like to look at the vents to see what you mean about putting them where you like ... and also, to see what you mean by "floor heat" - that's one thing I'm trying to achieve - getting the heat on the floor!
Also, are you saying that you can turn on the defroster independently from the heater? That would be great.
Alan
Old 03-24-2003, 06:28 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
Alan: I am using an OldAir Hurricane heat/cool unit on my '53 pickup. It is made to fit in the round hole on the firewall and is a small square box that is similar in size to the original heater unit. I will put on one of the reproduction Chevy heater decals and it will look a lot like the original!
<a href="http://www.oldairproducts.com/catalog/main_default.php" target="_blank">http://www.oldairproducts.com/catalog/main_default.php</a>
[ March 24, 2003: Message edited by: willys36@aol.com ]</p>
Old 03-24-2003, 07:40 AM
horvath's Avatar
Post
Well, Willys36, I see you're up to your usual stuff!
Too cool!
Am I right in thinking I can order just the "Inside Package?" I've already got the engine compartment stuff all in place ... right?
Also, where do you get the Chevy Heater decals?
Thanks, bro'!
Alan
Old 03-24-2003, 08:34 AM
Wiki Edits: 21
Post
Yes, that's what I did. Got the Hurricane unit, fan, control switch, and defroster from OldAir. I usually get my condenser with integral fan from some foreign car and my Sanden compressor, both from the junk yard. Throw a new seal in the compressor, polish it and I am in business!
Get the sticker from Jinm Carter - for your truck it would be item #
DE212 - 1954-55 Chevrolet for recirculator heater.... $2.55
or
#DE210 - 1954-55 Chevrolet , for fresh air heater.... $2.55.
These are Mylar stickers, very good quality.
<a href="http://www.oldchevytrucks.com" target="_blank">www.oldchevytrucks.com</a>
Old 03-24-2003, 11:41 AM
horvath's Avatar
Post
Thanks a million, bro'.
Alan
Old 03-24-2003, 12:17 PM
EBlack36's Avatar
Rebuilt Excitment
Post
On my 36 I am using one of the Gen II systems that use the electric actuators (sp) instead of vacumn, with that you get true bi level overation like in a newer car. The sure fit mounts like the other gentlemen said. I am using that type in my 57 Chevy wagon. I don't know the current prices since I bought both units a couple of years ago. The one I am using in my truck is one I took out of my 36 when I put in the Gen II (it was not large enough for the sedan).
Old 03-24-2003, 02:42 PM
horvath's Avatar
Post
Thanks again, EBlack36
The Gen II sure is the best space-saver of 'em all ... I checked their prices, but the Evaporator Kit isn't included in their price list - only the Complete Kit - so I emailed them to get the price on it.
Old 03-25-2003, 03:27 AM
EBlack36's Avatar
Rebuilt Excitment
Post
It is also the most efficent as far as I am concerned, I am using R134 and it keeps my sedan cool.
Old 03-26-2003, 03:49 PM
Post
All you need is the unit that goes under the dash, it comes with the vents of your choice and for a little extra you can get a nice control panel, I wouldnt use the hoses thats on your truck now unless they are fairly new, the older hoses are not the barrier type and will not take the pressure very well of the 134A freon. You can get a hose kit for 95.00 and that includes the dryer and the bracket for it
