We're winning the case!
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 03-23-2003, 09:16 PM
maroongold maroongold is offline
Question ideas for undercoat on fiberglass body/fenders
What suggestions or experience have any of you had with coating/painting/protecting the underside of fiberglass components? I've been thinking about the spray on truck bed liner stuff. Also, how does powdercoating the frame compare to other options like POR-15 or paint or something else?
Thanks in advance.
Old 03-23-2003, 09:28 PM
Halloweenking's Avatar
Halloweenking Halloweenking is offline
Fantastically cannibalistic!
Post
For undercoating fiberglass I'd use POR-15 Pelucid. A polyurethane that will stand up to anything you can throw at it.
Powdercoating is a great option, it will stand up to nearly anything as well. Both powdercoating and POR-15 is very durable, but POR-15 is a bit less exspensive. Powdercoating you have many color options, POR-15 you are limited to a few basic colors and sheen choices. I recomend both, its up to you on what color you want to use and if you want to put the work into covering the frame yourself with the POR-15.
HK
Old 03-23-2003, 09:30 PM
pasadenahotrod pasadenahotrod is offline
Post
Many of the rodders around here have the undersides of fenders, bodies, splash aprons, and other open-to-the-road areas sprayed with a bedliner material in complementary colors to their paint, or plain black and then spray the matching paint over it. It sure eleiminates the "stars" you can pick up on our gravel-strewn freeways!
Old 03-24-2003, 05:58 AM
Will's41's Avatar
Will's41 Will's41 is offline
Post
I'm using colored gel coat for under my fiberglass. After all is sure holds up well on my boat! Here ia a link to were you can find it.
<a href="http://www.fibreglast.com" target="_blank">http://www.fibreglast.com</a>
Old 03-24-2003, 02:05 PM
c21kirksey c21kirksey is offline
Post
I have had great luck with having fiberglass fenders coated with truck bed liner spray. You can buy it from a company called duplicolor or better yet take the car to a Rino lined aplicator.
Old 03-25-2003, 07:21 AM
Talking
Thanks for sharing your ideas.
I felt that I was going down a good path and now I know I still am.
I think I'll powdercoat the frame, use truck bed liner on the underside of the fiberglass and highly consider POR-15 for anything else that will be left for me to do myself.
Old 03-25-2003, 03:05 PM
bomo bomo is offline
Post
that link wills41 gave you is a great company to do business with i have used them a lot, great products
bomo
Old 03-27-2003, 03:57 AM
Tom Ryan Tom Ryan is offline
Post
I have a 1967 Malibu Chevelle 327 engine--Looking for a standard hood of good quality. (NO SS HOODS)
Old 03-28-2003, 04:33 AM
johnsontw johnsontw is offline
Post
[quote]Originally posted by maroongold:
<strong>What suggestions or experience have any of you had with coating/painting/protecting the underside of fiberglass components? I've been thinking about the spray on truck bed liner stuff. Also, how does powdercoating the frame compare to other options like POR-15 or paint or something else?
Thanks in advance. </strong><hr></blockquote>
Old 03-30-2003, 05:14 AM
joe k's Avatar
joe k joe k is offline
Post
What is POR-15 and where do you get it?Sounds like something I'd like to use on the underside of my street rod. Thanks.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
