idendifying a sbc engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2012, 04:11 PM
hi i have just purchase a chevy small block for my project a 1966 chevelle malibu the numbers i found on the engine are 3914678 which show to be a 1968 302 can anyone help in veriflying this
Old 02-15-2012, 04:17 PM
http://www.nastyz28.com/sbchevy/sblock.php
Old 02-15-2012, 04:25 PM
This is the casting number for a 4 inch bore block from 1968, it could contain a 302, 327, or 350 crankshaft. There is a pad on the passenger side front of the block that just overhangs the head there should be an engine number and VIN number (unless the block's been decked) these will lead you to knowing what the original use was and its displacement. Barring that you need to measure the stroke, 3.00 inch is a 302, 3.25 inch is a 327, 3.48 inch is a 350.
Bogie
350 Crate Engine: Loud humming sound after engine warms up sofa1515 Engine 2 01-11-2010 06:48 PM
Engine Help. Engine Turns over Hard, like siezed yet runs awsome. Merle9069 Engine 3 10-05-2008 06:38 PM
I need engine mount bracket ideas 1930 chevy with 302 boss engine. Riley Engine 3 07-25-2008 07:29 AM
say you have a THOUSAND horsepower engine..... (technical engine question inside) lowROLLERchevy Engine 14 02-24-2007 08:26 AM
the best engine parts, chain vs. gear, engine combos jollygiant_57 Engine 6 05-01-2002 09:34 AM
