Ident this tool please - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2013, 11:17 AM
Last journal entry: Continuing BodModOp... Body Modifiation Operator
What is this is this thing that's been hiding out in my tool box for years?
The knife blade is about 3" long and pivots in the tapered brass piece. I've tried to use it as a chip chaser on the O.D. of tubiing but there are better ways of doing that.
All explainations are welcome and maybe for a good laugh... kinda keep it clean..... I don't think it's used at Planned Parenthhod.
ID:	70382   Click image for larger version
Old 01-08-2013, 11:59 AM
tool
i maybe all wet but it looks like a tool for planting flowers or potatoes
Old 01-09-2013, 06:28 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
takes place of prepration H
Old 01-09-2013, 06:30 PM
chevynut1's Avatar
x2
Old 01-09-2013, 06:54 PM
life is a temporary assignment
Never seen one before.. But it does look like it could hurt someone..
Old 01-16-2013, 06:18 PM
Mystery Tool
It's a cork bore sharpening tool. In chemical labs, corks were used to seal various size glassware. To put various sized tubing through the corks, cork boreing tools were used. Each boreing tool was a three inch long thinwall brass tube, externally sharpened on one end with a T-handle on the other. The set of boring tools, eight or ten total, were nested inside each other. When a tool got dull, you held it by the T-handle, put the tip of the conical tool in the opening, pushed the blade against the dull tube tip with your thumb and rotated the the T-handle until the bore tool was sharp.
Not funny but accurate.
Transmission ident StPat5837 Transmission - Rearend 3 09-07-2009 10:20 PM
help ident brake caliper 85406 Suspension - Brakes - Steering 4 07-16-2009 09:53 PM
help ident 6 cyl chev motor not jack Engine 4 04-24-2008 04:30 PM
C-4 Ident peter1612 Transmission - Rearend 1 03-31-2007 09:04 AM
C4 trans ident? ptsherman Transmission - Rearend 4 12-29-2004 07:27 PM
