Identification on a lt1 camshaft? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2007, 03:16 PM
Have a camshaft in my garage and would like to now how i can see if its a lt1 cam.
Old 06-13-2007, 03:35 PM
Bumpstick's Avatar
Hammer and a torch
As in lt1 (1970 era) or lt1 reverse flow cooling...? Also kinda need the number...
Old 06-13-2007, 03:41 PM
1970 what number
Old 06-13-2007, 04:46 PM
On the learning curve.
There should be a number on the end of the cam. Mine was on the distributor end. Mine was "179R", just to give you a hint of the number to look for.
Steve
Old 06-14-2007, 02:11 AM
There is no number on the end of the cam.Here comes all number on the cam:CMC,CWC,D1,C1,E,21,1.5,539,Its a yellow and red spot at the end of the cam.I do not think this is a original LT1 camshaft,maybe a copy of it.
Old 06-14-2007, 08:26 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
You can purchase a cam timing kit from a performance parts store. I'm not sure if Summitracing.com ships overseas but they have them. Then you can just follow the instructions and find out exactly what cam you have. It will tell you lift, duration, and separation angle with a little adding and subtracting. Its a pain and it takes a while, but its one way of finding out exactly what cam you have.
I don't know about over there, but here cams are cheap. You could just figure out which one you want and get a new one.
Old 06-14-2007, 08:55 AM
Its expensive in sweden,but,summit can send cams to sweden.
Old 06-14-2007, 03:42 PM
Okey,gonna look up that,or else gonna buy another cam,its not so very expensive.Is a 300hp cam from a 327 any good to have whit my heads, :3795896 60cc (327 hp) on a 350 orginal block (1987)
camshaft identification help yodert75 Engine 2 11-19-2006 01:31 AM
LT1 Camshaft goldenrog Engine 2 01-31-2006 09:27 PM
Identification of my Erson mechanical camshaft regens sum Engine 2 06-03-2004 03:23 PM
Camshaft identification help frog454 Engine 2 02-11-2003 05:31 PM
Camshaft identification 56classic Engine 1 09-22-2002 02:39 PM
