Identifie this chassis - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2009, 04:40 AM
I don't really know if this is the right section for this but i have this chassis if anyone can shed any light on it.
The chassis was bought as a model a based chassis with front a rear end set up for mustang II and a 302 and has a wheelbase of opproximatly 108 inch (i was on my own when i measured it) but i have had some conflicting suggestions as to what it actually is, from a willys to a sebring.
If i recall i was told it was a Classic Rods or Vitage Rods chassis and dates from the 80's.
Any info would be much appreciated as i don't want to be buying a mustang II front end to find out it is something completly different.
Thanks Bryan
Old 12-17-2009, 01:49 PM
amx180mph's Avatar
Cunningham and Hersh Hot Rods
Wow
Hey Joe
I could write a book on what is wrong on this frame but I will keep it to two points. First off that is a Mustang 2 upper A arm perch see attached photos. The front frame horns appear to be way to high to the rest of the frame just by the pictures I would say 6-8 inches too high. If that is the engine mount that the wood board is bolted to a small block Ford would have the bottom of the valve covers about the height of the cowl, making the angle of the engine to be around 35 degrees to get the tranny tucked into the tunnel (impossible). The wheel base should be 106 inches for 28-32 and the front frame horn should be about 5 inches from bottom of frame, center line of the wheel to the ground with the frame sitting on the floor. My professional advice would be to sell this frame and use a frame built for your project.
Name:	mustang 2 4.jpg
ID:	42638   Click image for larger version
ID:	42639   Click image for larger version
Name:	mustang 2 3.jpg
Old 12-17-2009, 04:23 PM
life is a temporary assignment
It is for sure a home made chassis..Mustang II front end parts should fit it..
((((My professional advice would be to sell this frame and use a frame built for your project.))))
I do have to agree on this..
Old 12-17-2009, 06:22 PM
What exactly are you building again?
Old 12-18-2009, 08:28 AM
dinger's Avatar
It looks a little like a dune buggy frame, the way the front perch is so high, like a strut type of chassis would be used. It doesn't look practical for any street rod application I could think of.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 12-18-2009, 03:35 PM
Irelands child's Avatar
It's for sure NOT based on Ford's Model A chassis. An 'A' ('28-'31)has a 103.5 wheel base, minimal rear kick up and none in the front - it's virtually a flat chassis. Of course, for a rat rod it could use anything.
This is TCI's version of an 'A' frame and while it has an IFS and a 4" rear kick up for coil overs, it is the same general shape as an OEM (and I have had an original '31 sedan body on it).
My opinion, if you can sell it, you might be best off. A workable 'A' chassis can be easily built with a welder and some 2x4 x .125 to .180 wall tubing and a pair of frame horn repair sections
Irelands child
Old 12-18-2009, 04:49 PM
I was origanally going to use the chassis for my 33 plymouth coupe but i have since sold this and now have a model y body ( slightly smaller 34 ). I do have another chassis from a Riley rm which i will probably use now due to the feedback i have, as for the pictured chassis, for what i paid for it i'll probably shove it behind the garage and just use it for it's metal.
Thanks for the replies, Bryan
Old 12-18-2009, 04:50 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'm thinking someone had an idea to recreate an Altered...
Which Chassis finish would you choose from these 2 options? uglyjeep Body - Exterior 11 10-11-2008 12:17 AM
Chassis and Suspension Books joe123 General Rodding Tech 6 09-22-2008 02:25 PM
s10 chassis vs. tube chassis penguinoitaliano Suspension - Brakes - Steering 2 12-28-2006 09:40 AM
First stage of rebuild, chassis first? Oz GMHR General Rodding Tech 6 06-26-2005 12:36 PM
HELP! New 32 Ford chassis issue RoadShow Body - Exterior 8 06-30-2004 07:50 PM
