identify 10 bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2005, 06:04 PM
New Member
identify 10 bolt
Hi Can anyone out there identify my 10 bolt diff it has the following no,s on the lh axle tube ACB246 1 it is from a coil sprung car and has pressed on axle bearings? it is 2.73 ratio Cheers Frank
Old 03-21-2005, 06:10 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Are you asking what axle it is? 7.5/7.625-8.2-8.5-8.875 type of thing?
What year of what kind of car did it come out of?
Old 03-21-2005, 07:21 PM
New Member
10 bolt axle
its an 8.2 dia ringgear i would like to know what sort of car its out of if possible its 62 in drum to drum
Old 03-22-2005, 05:47 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
This is the application list I have for the 8.2 inch axle.
The list shows cars from 1955 through 1964 with the third member style housing (similar to the Ford 9 inch set-up), and the 1964 through 1972 with axles having the standard housing style with a stamped sheet metal cover that bolts to the back.
Buicks:
Regal, Century, Wildcat, Gran Sport, Lesabre, and Skylark.
Chevrolet:
Camaro, Impala, Chevelle, Nova, Caprice, Chevy II, El Camino, Malibu, Monte Carlo, Nomad, Corvette, and Biscayne.
Oldsmobile:
Cutlass, F85, 442, Hurst, and Regency.
Pontiac:
Grand Prix, Firebird, Lemans, GTO, Tempest, Trans Am, and Bonneville.
How to identify the year of a Chevy 10 bolt rear End? frankenvette Transmission - Rearend 2 04-07-2005 10:14 PM
F-body differentials, 9 bolt Borg Warner vs. GM 10 bolt Mad Maggot Transmission - Rearend 8 02-17-2005 08:02 PM
10 bolt vs. 12 bolt. Iwanttolearn Transmission - Rearend 4 02-05-2005 10:32 PM
10 bolt to 12 bolt 1980Impala Transmission - Rearend 8 04-25-2004 04:48 PM
10 bolt or 12 bolt rearends ? a62chevy Transmission - Rearend 5 09-21-2003 05:16 AM
