Identify camaro spindles - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2006, 09:54 AM
propaneburner's Avatar
Last journal entry: Artillery wheels
I like to order dropped spindles for my 56 panel.
Welded in a camaro frontclip, but don't know witch year exactly.
On the spindles is the number; 371676 RH and 371675 LH.
Are the last two digits the year of make?
Also having some spare ones with the numbers;
329854 GM RH 16N
and 329358 GM LH 15N
Hope some one can help me out.
Thanks.
Old 06-10-2006, 04:39 PM
I just got a Camaro front subframe for my '57. I'll look at the casting numbers when I get home from work and post them in the morning. Mine is a 1977.
-Joe
Old 06-10-2006, 06:37 PM
hope it helps
hey i have a 67 camaro and my numbers are the same so maybe that will help you.
Old 06-10-2006, 11:31 PM
They must be first generation. Mine are either 371875LH or 371076RH. It's hard to tell with a flashlight and a full moon. Either way it pretty well rules out second generation spindles.
-Joe
Old 06-11-2006, 07:31 PM
abstruse dutch uncle
1st generation doesn't have a left and right knuckle/spindle. The steering arms and caliper brackets bolt on, so you must be reading #s off of the steering arm only if they are 1stgen. If the arm and knuckle/bracket are all one piece, they're not 1stgen.
Old 06-11-2006, 07:42 PM
More checking reveals 371676 RH and 371675 LH as single piece 2ndgen Camaro knuckles. The knuckle/spindle, steering arm and caliper bracket should be a single piece.
Old 06-11-2006, 10:56 PM
O.K. they are from a 2ndgen camaro.
Like to order a bushing and balljoint/tierod set all so.
And while looking in the summit catalog i found this.
70-72,73-74,75-79,80-81.
I know that i have 1 5/8'' lower arm bushings but are there other differences?
The best way should be somewhere where i can read the casting numbers i think.
As i live in the Netherlands , ordering something and finding out the sent the wrong parts is not a lot of fun.
Thanks all.
Old 06-11-2006, 11:54 PM
Last journal entry: Buick
Pretty much everything is the same for all 2nd gen Camaro front end components except the 80-81 has different upper control arm bushings.
Old 06-12-2006, 03:17 PM
O.K. anyone some recommandations for dropped camaro spindles.
Like to have some quality.
Thanks
drop spindles for 1st gen Camaro jacobm99 Suspension - Brakes - Steering 1 01-14-2012 04:11 PM
Can you help me identify these 32 Ford spindles? LittleTruck Suspension - Brakes - Steering 4 01-11-2006 09:21 AM
drop spindles for 69 camaro ? xdamxincx Suspension - Brakes - Steering 1 11-11-2004 01:03 PM
camaro drop spindles 67 camaro Suspension - Brakes - Steering 2 05-18-2003 04:28 PM
Bolt on front spindles for a 67 camaro for5 on 5 LAZYB Hotrodders' Lounge 2 04-25-2002 07:29 AM
