identify chevy steering column - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2007, 07:50 AM
GMR GMR is offline
Looking for help identifying this Chevy steering column. It's in a street rod and I know the steering wheel is from a Corvette. The wiring out of the column is elow. Thanks.
pin D purple
E black with yellow stripe
F light green
G black with white stripe
H gray
J brown
K blue
L black with blue stripe
M black
ID:	19314   Click image for larger version
Old 03-09-2007, 11:50 PM
willys36@aol.com's Avatar
Wiki Edits: 21
That looks like a pretty generic tilt GM column. About the only differences are in the length and in the end they used on the output shaft (double-D, couple of different splines), and whether it has the ignition switch in the column. Can't tell from your photos whether you have the switch but it looks like you probably don't. If your question is what the wires go to, do a search on this forum. That info has been posted on at least a couple threads.
Chevy steering wheel donor for 39 chevy? Chevy39 Interior 12 07-24-2009 09:00 AM
Steering Column Harness on a G-body 1982 SS Electrical 2 07-29-2005 01:06 PM
Rebuilding Chevy Van steering column Sly's 53 Suburban Suspension - Brakes - Steering 5 02-14-2005 07:43 AM
steering column conversion 1957 chevy pickup kyzer1 Suspension - Brakes - Steering 2 11-06-2003 04:36 PM
Steering Column Dress-up Kit Bill Ford Interior 1 06-11-2003 02:43 PM
