Identify this engine for me please. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2010, 06:02 PM
I pulled this engine out of a '69 Camaro dressed up as a Z/28 (at least I think it is). It's a x44 code car. The block casting # is 3782870. Crank # 3735236 and has a 4-bolt splayed main. Info I've read says the block is '62-'67 327 and the crank from a 283. I've also read that only the 350 blocks were used for 302s. I can find no engine identification on the block. No numbers on the pad in front of the head or numbers over the oil filter. Could this actually be an original 302? Thanks for your help.
Old 09-18-2010, 06:18 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
62-65 327 is the block casting from what I gather:
http://www.nastyz28.com/sbchevy/sblock.php
Old 09-18-2010, 06:20 PM
Custom10's Avatar
And also welcome to HRBB from up North!
Old 09-18-2010, 06:24 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Heres somethng for you to read it will help. http://www.chevy-camaro.com/faq/chev...o-faq-Z28.shtm . And welcome to the site.
Cole
Old 09-18-2010, 10:28 PM
You have someones home built 302. Splayed main caps are aftermarket, not factory. Should be a strong bottem end to build a hi winding motor. What cam and heads?
crate chevy 302? Vancouver Grand Prix Hotrodders' Lounge 106 12-31-2012 04:05 PM
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
383 engine tapping and oil burning- weird RowShan Engine 15 10-10-2009 05:07 PM
Help identify Mercury flathead engine / what clutch & transmission can i adapt Jean Phi Engine 1 11-08-2007 05:15 PM
help identify this engine mikeweyman Engine 10 06-04-2005 10:49 PM
