identify gas tank????? - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
Old 02-24-2006, 12:47 PM
can any body tell what this gas tank is out of.I was told 65 chev impala but that is a no.. I need help on this one because it needs a new sending unit
Quick reply to this message
Old 02-24-2006, 01:32 PM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
I didn't get an image, but Google "replacement gas tanks" and you'll get several suppliers that have tanks from many different cars that have photos. You can also get a universal sending unit and adapt it to your tank. JCW has them, around $20 shipping included. You just need to know the manufacturer or ohm range of the gauge. Search the JCW site for "fuel level", not sending unit, to find it.
Old 02-24-2006, 04:08 PM
I will have a pic shortly.Having problems sizing..
Old 02-24-2006, 05:16 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
I don't know what it is but from the looks of finish on the tank it has not been sitting under a vehicle. That as well as the mounting holes that are visible and the position of the sending unit leads me to believe it a in cab mounted truck tank. Any other opinions? Hopes this helps a bit.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 02-24-2006, 05:37 PM
73oldsman's Avatar
Similar to this, but not quite http://www.quantaproducts.com/prodin...?number=GM-55A
Old 02-24-2006, 05:56 PM
poncho62's Avatar
Wiki Edits: 5
I betcha its a 58-64 Chevy tank.......sits upright right behind the rear axle.
Although, I dont remember them having 2 openings. I believe gas lines and sender were all in one unit.
Old 02-24-2006, 07:07 PM
I took the sending unit out and it has to sit upright.You are right home brew.I have been away from this hotrod stuff for 25yrs.Got alot of catch up but haved learned alot in the past 6mth's.You people help out alot and I hope I can do the same some day soon.Now what truck?? Thanks so far....
Old 02-25-2006, 08:17 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
I would guess something emissions era, it looks like it has three lines coming off of the sender.
Old 02-25-2006, 08:24 AM
I am going to post closer pics shortly.This tank sits in this postion.It also has a drain plug on the btm.
ID:	10320   Click image for larger version
ID:	10321   Click image for larger version
Old 02-25-2006, 12:32 PM
home brew's Avatar
When you say sending unit are you talking about the unit on the side of the tank ot the center of the tank. Another guess - The center unit looks to have 3 openings which leads me to believe that one is a vent and the other two are for fuel lines. Could this be a newer tank with a supply line and a return line for a fuel injected motor?
Old 02-25-2006, 01:12 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I went to that Quanta site that 73Oldsman posted a link to, and actually looked at almost all of the GM passenger car tanks. None of them that I saw looked like that one.
Is there anything on the tank that would help to identify it at all? Embossed or stamped logos, numbers, words ... anything? (Even a munufacturer name would help)
You might try removing the sending unit itself, and looking for any type of ID #'s on it. Maybe even post a picture of it.
We deal with a company called Spectra Premium as well, who has a pretty good pictorial reference section. Unfortunately, that catalog doesn't appear to be available for download from thier website at this time.
Old 02-25-2006, 01:35 PM
66GMC's Avatar
Looking closer and thinking about it some more, I'm beginning to think "import".
-I think I see an "ND" which may indicate "Nippon-Denso"?
As others have pointed out:
- The sending unit is seperate from the outlet. Most domestics that I have ever seen integrate the sending unit and outlets
-The tank is mounted vertically, with a side filler neck ... implying either behind the rear seat or in-cab. I would think in-cab, due to the lack of rust.
Arguments against that theory are:
1.) In-cab tanks usually have a large mounting pad area that the tank "sits" on. They want the tank well-insulated against squeaks in the passenger compartment.
2.) Being that the tank has return line provisions hints at the possibility that it is off of something fairly modern. To my knowledge, mfr's are no longer putting fuel tanks in passenger compartments due to safety concerns?
Old 02-25-2006, 01:54 PM
tank #0154784 and the sending unit #KE30KR.
I gave one company the tank # and he seemed not want anything to do with it.If this won't work than a senging unit pic is next.Thanks
Old 02-25-2006, 02:11 PM
66GMC's Avatar
I just ran both of those numbers through SPI's on-line c/ref and came up empty.
Anything there that suggests a manufacturer?
Where did you find the "KE30KR"?
Old 02-25-2006, 02:40 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
That sure does look like a gas tank from a B-body wagon. Its possible that its from a 65 Impala WAGON. But I agree with what someone else said; too many hoses for a 65. I would also say that it couldn't be that old because its a Nippon Denso, but they made replacement tanks. It could be an aftermarket replacement for a slightly older tank, but I don't think even the california cars got all those Evap hoses until 70-71
Closed Thread
Gas tank leak. help plz Skipr Engine 5 12-24-2005 09:02 PM
32 'Tanks' gas tank - fuel surge/starvation? Limey Simon Engine 2 07-30-2004 02:18 PM
gas tank pressuring up montea General Rodding Tech 3 06-04-2004 09:37 PM
diesel in gas tank help asap mike69scj Engine 15 05-30-2004 10:52 PM
original 1936 ford gas tank fitting bomo General Rodding Tech 5 12-04-2003 05:20 PM
