Identify Holley Carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2013, 10:19 PM
I have a Holley Carb with these numbers 6R 5643B and no other identifying marks (except 255 on a butterfly) -- It's mounting dimension appear identical to Edelbrock, the secondaries and primaries are both 1 7/16" diameter. The secondaries are opened by a mechanical link. Can you tell me the model number for parts purposes and the CFM?
My application is street only on a near stock 1994 4.3L chevy V6 in a light car with manual transmission. As it is currently configured the linkage is pretty progressive, the primaries are 65% open before the secondaries start opening. I was thinking that perhaps I could disconnect the linkage to the secondaries and use it as a two barrel if it is too big for this engine
I know very little about this so any help will be gratefully appreciated.
Old 05-05-2013, 05:23 AM
Banned
check this out and see if this is your carb pictured.
holley identification?? - The 1947 - Present Chevrolet & GMC Truck Message Board Network
Old 05-05-2013, 09:19 AM
It certainly looks like the same carb and some of the numbers match --- If truly a 450 should be ideal for my car -- THANKS!
Old 05-05-2013, 01:52 PM
Unfortunately the rebuild kit mentioned in the article I was directed to is not correct for this carb -- Help is still needed
Help me identify Demon Carb Sunny General Rodding Tech 2 11-15-2012 10:25 PM
Identify Holley carbs/CFM? AC/DC Engine 5 10-21-2010 11:00 AM
Help me identify this carb please blue54 Engine 4 06-18-2009 07:45 PM
Holley Aluminum heads:Help Identify QtrWavDave Engine 3 10-05-2008 12:44 PM
trying to identify Holley carb from numbers pcoghlan Engine 3 04-06-2008 06:29 AM
