Identify Holley carbs/CFM?
I recently came across some Holley carbs. How can I tell what CFM they are? How does one identify carbs if there is no previous knowledge to what it is or trusting what someone tells you its suppose to be? Some of them are in pieces and a couple are complete. Thanks in advance.
numbers on the choke horn
you can check the numbers on the choke horn, it will usually have the model number that will let you know what it is
go to the mortec website, they have a ton of great information.
identify holley cfm
ok guys, the model number will be on the carb. but if it says model 4150, how do i tell if its a 470cfm or a 650cfm?
Thier will be 2 numbers on the air horn normally, 1 is a date code the other is a LIST number,date code is useless 'cause it doesn't say which decade, list can be referenced through various sources, post it and I'll bet someone will have an answer for you.
dave |
| That lousy Holley carb | cool rockin daddy | Engine | 30 | 02-29-2008 02:01 PM |
| edelbrock vs. holley carb | Super Chevy | Engine | 43 | 01-21-2006 09:55 PM |
| Holley throttle body | Kevin45 | Engine | 1 | 06-10-2005 11:46 AM |
| Carb comparison Demon vs Holley | DTL504 | Engine | 12 | 12-29-2004 02:53 PM |
| MSD offroad-6, MSD 8366 Distributor, Holley 950 ECU | izord | Electrical | 0 | 09-06-2004 02:16 PM |
