There is also a brake pressure differential valve used that will give you a brake failure warning lamp if desired. |
Update on '67 Mustang M/C
Installed it today (in my 1955 Ford) with the large port (line) to the front and the smaller port (line) to the rear. The M/C is mounted on the firewall high above the wheel cylinders. As far as residual valves....I have been told that the drum/drum/manual M/C's have built in residual valves. They didn't put seperate residual valves in the lines on the 1967 Mustang. Residual Valves are used mostly in under the floor installations where the M/C is below the wheel cylinders. I hooked everything up without residual valves and the brakes work just fine. Nice pedal and you don't have to pump them to get more pedal. It will lock up all 4 wheels on a gravel road evenly. Thanks.....Ron
| 1967 Mustang | Aleta | Introduce Yourself | 1 | 07-20-2006 02:50 PM |
| headers/carb 1967 mustang | exiled1 | Engine | 4 | 09-07-2005 11:26 AM |
| 1967 Ford Mustang | SexXxyStangChic | Body - Exterior | 10 | 08-29-2005 01:50 PM |
| 1967 Mustang Fastback BAD FRAME | naviator2003 | Introduce Yourself | 3 | 09-12-2004 07:16 PM |
| Anybody ever put a 429BB in a 1967 Mustang? | '67Pony | Engine | 4 | 06-14-2003 11:37 PM |
