Identify Rear Axle? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2012, 08:18 PM
andrewakessler's Avatar
Identify Rear Axle?
I'm in the process of trying to sell my old rear axle, but I have no clue what it originally came off of.
The numbers stamped on the axle are 22606822b (pic attached)
It's possible it originally came off of a Monte Carlo, but I have no sure way of knowing.
Anyone have an idea?
Thanks,
-A
ID:	69463   Click image for larger version
Old 11-29-2012, 08:29 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks,
-A
Looks like a 7.5" GM. More info here on ID'ing it, and here to check the gear ratio- people buying it will want to know the ratio and whether it's a posi or not.
The Following User Says Thank You to cobalt327 For This Useful Post:
andrewakessler (11-29-2012)
Old 11-29-2012, 08:35 PM
Great info. Thanks for the links.
Old 11-29-2012, 08:50 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You're welcome! Forgot to add that it's from a coil spring car (has the cast-in upper control arm mounts).
Old 11-30-2012, 05:59 AM
big gear head's Avatar
High Performance Rear Ends
Looks like a G body 7.5 to me too.
Old 11-30-2012, 08:57 AM
@big gear head: The G Body would make sense considering the previous owner used a G-Body (Monte Carlo) front clip on the truck.
Thanks,
-A
need to identify this rear end chevyresto1 Transmission - Rearend 1 12-05-2011 09:58 AM
Help identify rear bulldogmafia Transmission - Rearend 4 03-17-2009 07:22 AM
Please identify these kingpins or axle set up SpectreBoy Suspension - Brakes - Steering 1 11-18-2008 01:51 PM
Help Me Identify the Rear Axle in my project? Bud's 27 T Touring Suspension - Brakes - Steering 7 05-29-2006 10:01 AM
Rear End - 5 bolt axle shafts into 6 bolt rear axle??? Blue Chevy Transmission - Rearend 0 06-07-2002 05:23 PM
