Identify These Parts On My Chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2011, 01:19 AM
I'm new to Hotrodding, and I'm working on my first build, please identify the parts that is circled in Yellow and Red. I think the Red has to do with the AC, the Yellow has to do with ?, not quite sure. This is not my truck or build by the way, just using it as an example.
Old 07-16-2011, 01:40 AM
QParker's Avatar
Six Offender
yellow would be your brake booster and master cylinder (don't take apart!) just add brake fluid to the master cylinder when needed. (That's what makes you stop before you run over the neighbor's dog. Hate to get a rib through a good tire! )
correct on the purple, it's got to do with your AC and heat.
Old 07-16-2011, 07:13 AM
Yellow is the brake booster, Just make sure its connected to manifold vacuum, and you leave all the brake lines connected.
Red is the AC plenum, filter/drier (the round vertical canister), and the evaporator (its inside the plenum). It does not hurt to leave them in place even if the AC lines and compressor are not connected. However, you should plug the lines so that you don't get dirt and moisture inside (I think I see a plug on the filter/drier in the picture). That will make it easier to get the AC working later on if you decide you want it.
The blower motor is also mounted in the plenum over by the passenger fender. Its much easier to replace than it is on most cars.
Bruce
Old 07-16-2011, 09:27 AM
Not to be too picky but this is a GM system and doesn't have a "Drier", that canister is an "Acumulator". http://www.askjeffwilliams.com/auto-...ioning-system/
Old 07-16-2011, 02:41 PM
bigdog7373's Avatar
Of course it's fast
Should there be a "very" before "new"? Lol. Just messing with you.
Old 07-27-2011, 10:41 PM
klutchmaster427's Avatar
Last wiki edit: Automobile body and frame rotisserie
Last journal entry: Bell Crank Fix
Wiki Edits: 4
I know you're questions have already been answered, but just thought I'd say welcome to the hobby and enjoy! Feel free to ask questions here anytime you want!
SBC 350 Rebuild Help Identify Parts arnellwest Engine 3 07-15-2011 05:27 PM
Identify some body parts for me please impalaman63 Hotrodding Basics 2 02-19-2011 07:37 AM
Can you identify these parts scrot General Rodding Tech 0 01-09-2007 07:51 AM
7004r With Photos Identify Parts 123pugsy Transmission - Rearend 13 04-24-2006 06:22 PM
Help identify nos parts citykid General Rodding Tech 4 01-01-2004 11:12 PM
