Identify this tool set. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2008, 09:43 PM
CrashFarmer2's Avatar
Dried up in the Drought! :(
Last wiki edit: Pre-1980 VIN decoding
Last journal entry: 1978 Chevy pickup battery tray repair
Wiki Edits: 409
I bought this set of tools at an auction today. as near as I can figure out it is used to drive out stuck bolts. There are five different thread sizes. a couple of them look like they have been pounded on pretty hard.
I thought they looked interesting so I bought them.
ID:	29988   Click image for larger version
Old 05-17-2008, 10:13 PM
RODDER18's Avatar
Are they tapered on the inside? It almost looks like a set of wheel lock and hub cap lock removal set from the 80's. You would hammer the closest size on to the smooth wheel lock or hub cap lock to remove them if you did not have the key. The first ones out were smooth on the inside and then they started making them with aggressive reverse threads on the inside.
Old 05-17-2008, 10:31 PM
Wiki Edits: 409
I don't see any taper and the threads are not reversed.
Old 05-17-2008, 10:51 PM
RODDER18's Avatar
They could be used to remove wheel studs on trucks. An example would be a 3/4 ton chevy pickup, you have to pound out the wheel studs to replace the brake rotor. The same is true for removing studs from axles, of course this is just a guess.
Old 05-18-2008, 12:14 AM
dinger's Avatar
My thought also.
Old 05-18-2008, 12:25 AM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Hey Crash that's a older wheel stud installer set. I worked with a older mechanic that had a set of those in my teenage years.
Old 05-18-2008, 07:04 AM
Marcel
Last journal entry: Choo-choo town
I d this tool ?
If they're for wheel stud removal, whats the hex on the outside for?
I always used a nut (flat side up) run down flush with the stud to remove a stud that was to be replaced. If not for reuse, just hammer it out. One just lick works most times, if it messes up the threads, so what you not reusing them anyway. I used a couple of washer and a new nut to pull them in when replacing them (I use an impact wrench, just be sure to stop when it's pulled up
My guess would be something to set (install) some type dial pin that would only install to a certain depth, The hex still has me stumped.
Basic Air Tool Set Help leejoy Garage - Tools 5 09-15-2006 07:48 AM
Bought a Cutoff & Talk Hf Tool policy 1Fast65Elky Garage - Tools 22 09-04-2005 11:46 PM
push rod clearance tool lanierledford Engine 1 07-04-2005 08:32 PM
Holley choke set screw lluciano77 Engine 11 08-05-2004 10:20 PM
Where to get a set of Unilug washers and nuts to fit? Dubz Hotrodding Basics 1 07-06-2004 07:33 AM
