Identifying a posi Unit - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2006, 02:34 PM
Hi I've had a posi unit for about 20 years now that I have no idea what it is for. It doesn't have a ring gear on it. Can anyone help me identity it. It has 10 bolt holes the only markings that I can see are a 760 E 931 stamped on the side.
Old 08-29-2006, 09:49 PM
Bumpstick's Avatar
Hammer and a torch
If we could see it then it would be much easier... (not to sound sarcastic) Just post a pic...
Old 08-31-2006, 10:04 AM
Here are some pictures of the posi unit. If I counted correctly it has 26 spline gears.
Thanks,
Kent
ID:	14533   Click image for larger version
ID:	14534   Click image for larger version
Old 09-11-2006, 08:51 PM
Bumpstick's Avatar
Hammer and a torch
It looks like one of the early non-rebuildable Auburn posi units...?
But really I think its a 7.5 limited slip like from a Trans Am or something along those lines...?
Old 09-11-2006, 09:56 PM
Mr 1984
Yup, looks like an Auburn style limited slip and is very similar to the Auburn type that came in the 8 3/4 Mopar from about 69 and newer. Can't be rebuilt? Well, for the Mopar units, there's no "serviceable" parts available for them and are considered unrebuildable too but if they are not totally burned up, they can be machined to work again. Been doing that for about 20 years now and they work very well.
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 04:00 PM
posi unit for 1971 Camaro todel1223 Transmission - Rearend 2 09-12-2005 12:22 PM
posi unit and axel combo malibu68 Transmission - Rearend 4 04-11-2005 10:50 PM
posi unit identification malibu68 Transmission - Rearend 2 03-27-2005 11:57 PM
Which Posi unit to buy? F-1 Rodder Transmission - Rearend 6 02-05-2002 03:53 PM
