Ididit Column compatability to 1953 F100 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2013, 12:57 PM
I purchased an Iditit steering column, to go in my 1953 F100. I would like to use my stock steering wheel, that has the 50th anniversary horn button. Any ideas how to make it all fit together? Ididit is no help. Thanks everyone.
Old 05-06-2013, 04:02 PM
Irelands child's Avatar
It wont work.
You can purchase an adapter from several sources that will work with the Grant steering wheels (5 bolt) or the rest like Le Carra (9 bolt). Other then that, you will have to either fabricate your own adapter or modify the wheel you have to fit the IDIDIT taper and a universal adapter. If you look at the IDIDIT website or one of their catalogs, there is absolutely nothing that says that universal column will fit up to any OEM wheel tapers plus have a working horn (IDIDIT uses GM contactors).
Irelands child
Ididit steering column problem jkeller Electrical 4 03-05-2013 06:07 AM
Ididit column not grounded RatPin Electrical 9 10-18-2012 10:56 PM
Ididit steering column Ziggy1805 General Rodding Tech 14 10-15-2008 07:57 PM
clunk in Ididit steering column cares Suspension - Brakes - Steering 8 06-05-2008 05:44 AM
Ididit Shorty Steering Column Question seadog Suspension - Brakes - Steering 2 05-10-2006 03:47 AM
