Ididit Column with shifter - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2013, 11:30 PM
Who has used this column with built in shifter? Was it a good design to hook up to the transmission? Do they fit and shift nice? Thanks.
Old 06-02-2013, 12:27 AM
techinspector1's Avatar
Wiki Edits: 326
It helps when asking a question such as this to include a link so that the rest of us who have no experience with this product, can take a look.
Old 06-03-2013, 06:41 PM
Last journal entry: 41 chevy frame on the move.
Couldn't open up ididit web page,but here's a link to summit.
http://www.summitracing.com/search/P...ering-Columns/
Old 06-03-2013, 06:51 PM
sedanbob's Avatar
I put an Ididit tile column with shifter in my '33 sedan. Installation was easy, and it shifts fine. The linkage from the column to the transmission had to be trimmed to length as it was a universal linkage.
ID:	74600   Click image for larger version
ID:	74601   Click image for larger version
Old 06-03-2013, 07:09 PM
sedanbob's Avatar
One thing to add - the large diameter portion of the Ididit tilt/shift column is longer than the Flaming River tile/shift column. It might not matter in your installation, but I had to re-locate my column drop 1 1/2" closer to the firewall because I didn't allow for that when I ordered my column. Mine was a universal column - if yours is specific to your car, that shouldn't be an issue.
Old 06-03-2013, 08:00 PM
Irelands child's Avatar
IDIDIT columns are quality products. With that said, if it's for a vehicle that is being newly built or just retrofitted, there will always be some amount of trial and fit up time to make it work well as seldom does anything drop in place and work right out of the box perfectly There are just too many variables between vehicles for a manufacturer to account for in his design.
Irelands child
Old 06-04-2013, 01:59 PM
sedanbob's Avatar
I agree completely! The one thing that can be said about a 'universal' part is that it universally doesn't fit anything. I can't think of many things on my car that did not need to be modified in some way. I splurged on the billet universal ball mount for my column at the firewall - $100! Within minutes I was grinding on it because it wouldn't adjust the last few degrees I needed.
Ididit Column compatability to 1953 F100 superfsr Suspension - Brakes - Steering 1 05-06-2013 04:02 PM
Ididit steering column problem jkeller Electrical 4 03-05-2013 06:07 AM
Ididit column not grounded RatPin Electrical 9 10-18-2012 10:56 PM
Ididit steering column Ziggy1805 General Rodding Tech 14 10-15-2008 07:57 PM
clunk in Ididit steering column cares Suspension - Brakes - Steering 8 06-05-2008 05:44 AM
