We're winning the case!
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 05-08-2006, 02:59 PM
seadog seadog is offline
Ididit Shorty Steering Column Question
This is a little hard to explain verbally, and I don't have my camera here so can't take a picture. Here goes....I'm using an Ididit Shorty column on my Deuce 5 window project. I have the column mounted in the car and am in the process of measuring for the joints and linkage needed to hook the column to the steering, which is a rack & pinion unit in a Kugel indy front end. It's a fairly straight shot and I should be able to get by with one u-joint and one support bearing between the firewall and the rack. I will be using 3/4 inch X 36 splined steering shafting. My delimma is how best to finish off the hole in the firewall where the 3/4 inch shaft will come through. There is a flange bearing on the inside of the firewall, but how is the best way to finish off the other side so that there's not just a 3/4 inch shaft poking through a raw hole? Everything I've seen in pictures and at shows involves longer columns that have the end of the column sticking through the firewall and thus present a more finished look. Has anybody else confronted this problem when using a Shorty column? Thanks
Old 05-08-2006, 05:18 PM
Deuce Deuce is offline
Deuce's barnstar
Wiki editor
Last wiki edit: Wheelbase database
No real help from me ...
I always use a GM van tilt column ... and they are longer than the Ididit short one. I do make a cover ... to cover over the hole ... because the hole is larger than the column diameter ... to allow for the shifter arm ...
Old 05-10-2006, 03:47 AM
staleg staleg is offline
Street Rod Builder Magazine did an article on this a few months ago.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Ididit Shorty Steering Column Question"
Loose Gm Tilt Steering Wheel Moves Up And Down fumplet Suspension - Brakes - Steering 7 02-25-2006 03:18 PM
'39 ford steering column and wheel jim williams Suspension - Brakes - Steering 4 01-27-2004 07:28 PM
39 Chevy Steering Column Beenaway2long Suspension - Brakes - Steering 6 01-08-2004 04:52 PM
EZ-Wire : Reading Wires From Steering Column horvath Electrical 2 03-23-2003 04:56 AM
tilt steering column sweethome18 Hotrodders' Lounge 4 10-23-2002 07:35 PM
