Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ididit steering column problem
Old 03-04-2013, 06:58 PM
33Willys77's Avatar
33Willys77 33Willys77 is offline
Sounds like when the signal mechanism inside doest not cancel all the way and will not let the brake light to function through. I am assuming you are using the left turn signal when changing lanes. If you push the lever just a little more to the right, it would probably work. Something might be a little too tight not allowing it to return to it's 'home' when you release the lever. I never had one, but I believe they use the GM signal switch - might need a new one if you can not free it. Just some thought here.
