Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ididit steering column problem
Old 03-05-2013, 07:07 AM
Bryan59EC's Avatar
Bryan59EC Bryan59EC is offline
Car? Truck? Who Cares
Last journal entry: First week of December
Originally Posted by 33Willys77 View Post
Sounds like when the signal mechanism inside doest not cancel all the way and will not let the brake light to function through. I am assuming you are using the left turn signal when changing lanes. If you push the lever just a little more to the right, it would probably work. Something might be a little too tight not allowing it to return to it's 'home' when you release the lever. I never had one, but I believe they use the GM signal switch - might need a new one if you can not free it. Just some thought here.
Standard 69+GM switch is used in these.
Could try loosening the 3 mounting screws a bit and then snug them up again.
Probably binding.
A weak cancel arm may keep the switch from fully returning as well.
The Following User Says Thank You to Bryan59EC For This Useful Post:
jkeller (03-05-2013)
