-   -   Ididit steering column problem (http://www.hotrodders.com/forum/ididit-steering-column-problem-230327.html)
jkeller 03-04-2013 06:22 PM
I installed a Ididit column on my 57 Chevy 210 and have found out that after I use the turn signal to change lanes my left brake light want work. If I use the turn signal to turn on a street and let it cancel on it's own the stop light works OK.
If anyone has experienced this problem with Ididit columns please let me know what I need to do to correct this safety problem.
MARTINSR 03-04-2013 06:56 PM
Post your question in the electrical forum for many more responses than you will get here. Electrical - Hot Rod Forum : Hotrodders Bulletin Board
WELCOME! :welcome:
33Willys77 03-04-2013 06:58 PM
Sounds like when the signal mechanism inside doest not cancel all the way and will not let the brake light to function through. I am assuming you are using the left turn signal when changing lanes. If you push the lever just a little more to the right, it would probably work. Something might be a little too tight not allowing it to return to it's 'home' when you release the lever. I never had one, but I believe they use the GM signal switch - might need a new one if you can not free it. Just some thought here.
jkeller 03-04-2013 09:39 PM
Thanks for the suggestions. I will give it a try and see if I can get it to work before replacing it. I will keep you posted.
:welcome:
Bryan59EC 03-05-2013 06:07 AM
Standard 69+GM switch is used in these.
Could try loosening the 3 mounting screws a bit and then snug them up again.
Probably binding.
A weak cancel arm may keep the switch from fully returning as well.
