Ididit steering column problem
I installed a Ididit column on my 57 Chevy 210 and have found out that after I use the turn signal to change lanes my left brake light want work. If I use the turn signal to turn on a street and let it cancel on it's own the stop light works OK.
If anyone has experienced this problem with Ididit columns please let me know what I need to do to correct this safety problem. |
Post your question in the electrical forum for many more responses than you will get here. Electrical - Hot Rod Forum : Hotrodders Bulletin Board
WELCOME! ![]() Brian |
Thanks for the suggestions. I will give it a try and see if I can get it to work before replacing it. I will keep you posted.
Could try loosening the 3 mounting screws a bit and then snug them up again. Probably binding. A weak cancel arm may keep the switch from fully returning as well. |
| The Following User Says Thank You to Bryan59EC For This Useful Post: | ||
jkeller (03-05-2013) | ||
| Ididit column not grounded | RatPin | Electrical | 9 | 10-18-2012 10:56 PM |
| Tilt steering column Ididit or Flaming river. | speedydeedy | Hotrodders' Lounge | 10 | 04-04-2012 03:23 PM |
| Ididit steering column | Ziggy1805 | General Rodding Tech | 14 | 10-15-2008 07:57 PM |
| clunk in Ididit steering column | cares | Suspension - Brakes - Steering | 8 | 06-05-2008 05:44 AM |
| Ididit Shorty Steering Column Question | seadog | Suspension - Brakes - Steering | 2 | 05-10-2006 03:47 AM |
